I decided to go forward with raising the height of the bulwarks. The plans show that the bulwarks were supposed to by 9/16" in height. At scale the height would have been 4'5". As built, the height is 6/16" or 3'. This is why no one's guns fit anywhere near square in their ports. I decided to add 1/8", or 1 foot, to the bulwarks as a compromise. I made the decision based in part on art (how will it look once finished) and in part on a re-scaling of the guns and carriages. Keep in mind that the finished thickness of the bulwarks is 1/8".
Initially I thought to do the task with 1/8" square stock. Happily, I didn't have any! I have lots of 1/8 by 1/16 and decided to laminate. This was the right call because I had to edge bend to get the new wood to follow the curve of the bulwarks from the stem to just before the lovely curve of the stern. You might say that I could have avoided the edge bending by sitting the wood on it's 1/16 inch side and bending it as if I were planking the hull. I rejected that idea because, with the tools at my disposal, including clamps, I believed that I would do harm to the copper plates and perhaps the hull.
First I removed the 1/32" square material used as port stops from the fore and aft sides of each port.
My process was to soak the 1/8" x 1/16" wood in hot water and apply some heat from my electric plank bender. I then clamped and pinned the pieces to the hull and let them dry. For the first layer of new wood, I cut the lengths into sections I could easily work with - short enough so the combination of CA and wood glue would be workable without making a mess. The second layer was shaped using the same method, but I was able to lay it down in one piece because I now had a very even and completely clean surface of wood to attach to.
Photos - 1 Port lid stops being removed, 2 First six inches
of height is down and attached and second layer drying in place, 3 Bulwark height now at a scale 48 inches.
View attachment 428726View attachment 428727View attachment 428728View attachment 428729
