yes.. we can give them even more sharp angle slacking first couple of shrouds and slacking parrals as much as possible , but main stay couldnt be slackened, there is limitation
For good or for bad ... I'm serving the portion of the backstays that will wrap the mastheads as we speak. I can't wait to hear the collective UGH - I CAN'T BELIEVE HE DID IT THAT WAY!Well Paul,
It seems I've just traversed the information gauntlet that your build log is famous for.Now it's a matter what to do (again, kind of reminds me of picking out wallpaper with the admiral). At any rate I cannot think of a better venue than your Vasa log for this, thanks. PS... Let me know what you're going to do
, I've got a week or more of ratlines to do.
It's worse than that Kiril. To run the backstay to the channel means it has to pass THROUGH the shroud set. I think I need to run it aft of the shrouds.Lets narrow our discussion to exactly What Fred H says about posible location of Vasa backstays:
"...backstays each, the mizzen only one. As far as we can see, there is no evidence for topgallant backstays, although it is not impossible.
The backstays are not set up on the aftermost chain as in later ships. On the mizzen, the backstay looks to be between the third and fourth shrouds, while on the mainmast and foremast there appears t be a backstay between the last and next to last shroud, and possibly one farther forward. ... "
As we could see , in this backstays location , they also will never touch the yard when it bracing, only fist couple of shrouds could touch the braced yard...
By the way,Paul, Daniel,
if we will set backstays as FH advised their locations, between shrouds, how they will pass top mast fighting platform, will not touch it and bent over it?
Interesting that Kalmar Nykel replica has it setted far to the stern after last shroud, but not between them...as FH sugested
Yes...run trough shrouds ...and whats wrong with it?It's worse than that Kiril. To run the backstay to the channel means it has to pass THROUGH the shroud set. I am going to run it aft of the shrouds.
I too will run my backstays aft of the shrouds, I actually have a little room aft of the aft shroud line on my fore and main chain walers. Enough room for at least one backstay and the topgallant of both locations may have to go onto side bolts. I have options just need to sort it out.Lets narrow our discussion to exactly What Fred H says about posible location of Vasa backstays:
As we could see , in this backstays location , they also will never touch the yard when it bracing, only first couple of shrouds could touch the braced yard...
By the way,
Paul, Daniel,
No, because you need to read what I wrote, when bracing the sails the backstay interfere with it. There is more than just a yard. It's called a running stay. In Dutch slingstay. This name describes the function. Explained in that document of 1842.You make simple scketch? Braced yard touches backstays...
In a other post I exactly explained you how and what, with drawing, how it was done. Page 133 or so. I said there we both did it wrong.Are they talking exactly about backstays which are positioned behind aftermost shrouds, far to the aft, or they talking about something else?
Good day Stephan,No, because you need to read what I wrote, when bracing the sails the backstay interfere with it. There is more than just a yard. It's called a running stay. In Dutch slingstay. This name describes the function. Explained in that document of 1842.
But feel free to have your opinion on this. I respect that. I do not feel like translating that document into English. I gave a summary of what it says. That is enough. You can accept it or not. But if you are going to comment, please read carefully what I wrote before.
I cannot give you more information than is written there. What I think is enough info to give yourself an idea how it probably looked like. I have already said enough about that. And given enough examples.
I think your model is coming together extremely well and I am glad you have your own decisions in this model!! Make it's more personal to you and I think it helps with continuing on to the end.I want to begin by thanking all of you for your continued interest in my build and for the active participation of many as I struggle to work out the details. While I have to accept that every question I would like answered can't be answered - and that I will make errors in judgement and execution along the way - neither do I want to be dismissive of the simple fact that I am building a model of a real ship with real history.
Over the past several weeks I have come near to completing the standing rigging. I have made some decisions along the way that not everyone will support but that's OK - it wasn't for lack of time spent trying to figure things out.
My customary blue background didn't cut it for pictures of rigging, so I cobbled together a few pieces art board that my kids had lying around... and now that I see the photos I regret not taking the time to set up proper lighting...
The overall view:
Mizzen:
Main:
Fore:
Sprit:
And I chose to rig the top ropes just for fun. Obviously these lines would have been taken down once the masts were raised but I think they make a nice addition to a model and could create a worthwhile talking point. I only did these for the top masts not the topgallants...
I'm confident, given the attention they have received on this log, that you didn't miss the fact that backstays are not rigged. Research continues with the hope that more can be learned.
Fun fact: I have now used nearly 60 meters of the smallest rope (roughly 0.24 mm) I can make from my chosen source threads. Most of this went to ratlines but also lanyards in a few spots. While there is great satisfaction in rope fabrication - I'm no longer sold on the (time) cost to value ratio.
Thanks for stopping by! It's a joy to share this journey with you!
