VOC SPIEGELRETOURSCHIP BATAVIA 1628 - KOLDERSTOK 1:72
Back to reality and back to the Haarlem. Next up chain plates (rusten)
Rear deck portion - starboard
Deck Starboard
Forecastle starboard
Deck Top View showing starboard and port side chain plates.
Forecastle top view showing chain plate son both Starboard- and port sides.
Work started on the gunport lids - lots of fine tuning and finishing still required here.
Overview of all chain plates in position.
And a final overview including the galleon and bowsprit.
I am really happy with how she is turning out. This ship has been a lifesaver during these times - working on her has kept my mind free from all the life challenges that lie ahead - even if it is only temporary.
Thank you all for watching, following, commenting and supporting us during these times! I cannot tell you how much it is appreciated!
H
Looking great Heinrich! I agree ship building is my solace as well! I put on some relaxing music, usually instrumental like classical, and get lost in the build! ;)
Dear Heinrich, you promised to reduce the multi-meter bays of gun hoists.And why are they stretched over cargo hatches?Some kind of pun.:oops::rolleyes::D:D
Dear Mr Deep. Thank you very much for checking up on me with regards to the rope coils. I promised you that I would reduce their size and I will keep my promise. The problem is that I might be moving house soon and at the moment I am just trying to do as much work as I can on the exterior of the hull. But I will keep my promise!
Now the cannon rigging:
This was what I had wanted to do as this is the correct way of rigging the cannons on a Dutch ship. However, this picture was taken from the Zeven Provincien which has a much wider deck than the Haarlem.
This was my problem on the Haarlem - there was just no space for the anchoring blocks. If I had mounted them where they should have been, the blocks would have touched.
So I was forced to opt for this layout which is used by some of the Dutch modelers when there is a lack of space.
I hope you understand why I chose this route.
Looking good Heinrich. I find myself working on the same thing right now. Did you add pins to hold them in place?
Hi Paul. Thank you for the kind words! Yes I added two pins to each chain plate on the outer ends. They are as solid as a rock. By the way, if you are doing chain plates, then you are not far off doing the deadeyes. There is quite a novel method used by one of the Dutch builders where no wiring is used to secure the deadeyes. He uses ropes which create a MUCH neater effect. I have never done it though, but I would like to give it a go.
@Dean62 Thank you my friend. Solace is the perfect word and when I am involved in research everything stops for me. I sometimes glue something on the ship and while it drying, I do some further reading on the Dutch ships. The next moment I regain "consciousness", it is two hours later and the glue is well and truly dry! :)
Deck Starboard
H
I assume rusten means “rests.” A friend had a business called “Seldom Rest” in New York. He said his ancestors in Holland had a sign over their farm’s gate saying, “Zelden Rust.”
@RDN1954 I can well believe that Johan. In South Africa the farms are big (especially the livestock farms) and it takes farmers sometimes a whole day just to visit all the camps. In the old days when it was done on horseback, it even took days. Even today there are still farms where the impassable terrain makes the use of cars and "bakkies" (light trucks) impractical.
@Peter Voogt Thank you very much for the kind words, Peter. You can imagine that with only little more than a month in which students can book classes, they are trying to cram in as many classes as they can. This means that I have little time for anything else, but when I do, it is all spent on the Haarlem.
