Good afternoon, all, the top wing ribs are all in as you can see from this overall shot. The trailing edge is a 0.35mm wire glued into a notch on the aft ribs. You can barely see the wire, but I have weighted it down in the first 8 grooves (working from the center out each way) and applied a touch of epoxy at each joint. When this sets up, I'm hoping it will be anchored and I can glue it down out to the ends.
The two aft ribs are much shorter and have no ledge to rest on, so I had to fabricate a rest. In addition, the instructions said to fabricate the last shortest rib from scratch, you can see its homemade look.
I do not see any way this model design will support a stress related silk span, shrinking and doping method of wing covering so I have chosen to do what the Wright Brothers did and cover them in an off-white muslin non doped covering. The next photos are what I am aiming for.
I was so glad my sewing days were over when I completed the sails for the Blue Nose. Well apparently, not so I leave you with this last photo.
Till next time I hope you all have a wonderful time.
