Hallo @OsaulMy second building Bonhomme Richard section by Unicorn,
first building: https://www.shipsofscale.com/gallery/osaul/bonhomme-xsection/index.html
Are you working actual on a project?
Ha Ha - it is never too early - sometimes also the researching of information about a ship could be interestingHello, Uwe! Thank you very much! It's too early to show the current project
Thank you for your advice. I will reconsider my strategy. The thing is that the hull of this ship will be multicoloured (see picture) when finished, that is why at first thought it might be wise to dye the seperate planks beforehand. Do you (or anyone else) have any suggestions what this 'orangy' colour is? Occre does not specify this.I always stain after completing sanding of the second layer of planking. I always use Rustins oil based stain (available on Amazon) and have for many years on all types of projects - never a problem.
You are right, I will just start planking and continue my search for the proper colour. It is a light coloured wood indeed (sycamore), you can see the bundle in the last picture. The darker planks below the waterline are sapelli. I have also send a mail to Occre.Google search 'Rustins wood dye colour chart'. Pine stain would seem to be the closest but, of course, it depends on the type of wood you are staining and I am assuming it is a light coloured wood. Since that light strip is between the wales you will get away with staining it after planking.
My personal opinion: The orange colour is not looking very realistic - because as I know the hull would not have been painted in this way - this part of the hull would be "natural" woodThank you for your advice. I will reconsider my strategy. The thing is that the hull of this ship will be multicoloured (see picture) when finished, that is why at first thought it might be wise to dye the seperate planks beforehand. Do you (or anyone else) have any suggestions what this 'orangy' colour is? Occre does not specify this.
Hello Graham and Uwek. Occre has confirmed it's Pine stain (Tinte Pino). They also added: 'Apply several layers until the desired tone is obtained'. So I now suspect this overly saturated orange colour can simply be avoided by holding back on the number of layers. I will order it and try.Google search 'Rustins wood dye colour chart'. Pine stain would seem to be the closest but, of course, it depends on the type of wood you are staining and I am assuming it is a light coloured wood. Since that light strip is between the wales you will get away with staining it after planking.
Why not starting a building log of your project? Would be best way to show us your progressCommencing second planking of Endeavour. A close-up impression.
Yes, why not? The answer to that could be that I fear I will feel the obligation to update regularly. On the other hand it seems to be the only logical next step - so I will give it some serious thought.Why not starting a building log of your project? Would be best way to show us your progress
Wowww that is some great work!!! It look beautiful!!! Please keep on sharing with us!Sergal Vasa, 2nd build. A bit over 1.5 years into the build. Feedback appreciated. View attachment 383663View attachment 383664View attachment 383665View attachment 383666
Hallo Christian,Here are two pictures from my current project HM Cutter Alert, 1777 in scale 1/36. The model will be build following my own research and drawings. Especially by the frame design you will see a lot of differences to the from Goodwin published version
View attachment 395013 View attachment 395014
I run into a small problem with the jig. It is to precise - it helps me perfect to align the frames but if I will glue the frames to the keel I could not remove the finished assembly from the jig.
In the moment I am busy to redesign my keel and deadwood structure to correct some smaller issues at the stern.
This is brilliant construction Christian! I love the precision and know how difficult that is to achieve! Even if you don't want to create a build report we would all be blessed to see more progress reports on occasion!Here are two pictures from my current project HM Cutter Alert, 1777 in scale 1/36. The model will be build following my own research and drawings. Especially by the frame design you will see a lot of differences to the from Goodwin published version
