current build images Your actual Ship Modeling Project - briefly introduced at a glance -> present it here
Hello @Uwek
I have started to many build logs in the past and not finished the model. That is the reason why I did not start a log for my current project. I am afraid that this will happen again. I don't know when it is for me the best time to start a log, but in the moment I feel that it is much to early for a new one.
For us it is important, that we share knowledge and get information to see how and what others are building. Every single post can be helpful for one or another modeler in our community. And it is not important, that at the end there is a completed build. It is a nice to have, but not most important.
My current project is the Golden Rule, a 30-foot Angelman ketch that sailed from Hawaii in 1958 to protest the Marshall Islands atomic bomb tests. I obtained a copy of the original Angelman plans and am building the model according, but am incorporating details, paint schemes, and sail designs from the new version that was restored in 2015. It is being used by the Veterans for Peace organization as a floating ambassador for their anti-war and anti-nuclear message, and recently completed the “great loop” voyage down the Mississippi (starting at Minneapolis), around Florida, up the East coast as far as Maine (where I saw her in person), up the Hudson River, through the Erie Canal to the Great Lakes, and ending at Chicago. Attached are photos of the boat itself and my 1/32 scale model in its current state. The Golden Rule website is: https://vfpgoldenruleproject.org/
James
Maine
Wowww that is some great work!!! It look beautiful!!! Please keep on sharing with us!
Thanks, @Polo . I am going to redo the klinker planking of the upper part of the hull, because the run should be parallel to the railings above. @Ab Hoving was kind enough to notice and help guide me before I kept going. So, I am going to start working on that just as soon as life allows time to continue the build.
С днем рождения!!!
почти готовая сборка Corel's King of Prussia по планам. просто нужно закончить задние стойки, повесить флаг и подвеску, сделать несколько мотков веревки и несколько небольших подправок на отделке. Я фрезеровал обшивку из ели, но не рекомендую это делать, так как текстура может быть немного грубой и плохо гнётся (хотя на самом деле кромка гнется довольно легко, подумайте), и заказала блоки и такелаж по мере необходимости. . все остальное сделал на своем мини-настолке пилой и защелкой, включая анкеры. Я опубликую ее на форуме завершенных сборок, когда все будет готово. любые комментарии и/или критика будут оценены по достоинствуView attachment 229619View attachment 229622View attachment 229620View attachment 229621View attachment 229622View attachment 229623
Разрешите присоединиться к радости и поздравлениям! Ваш корабль великолепен!! Не могу найти слов восторга, когда вижу такой красивый корабль!! Желаю Вам успехов и удачи в работе! И пожалуйста создайте любой другой корабль! Желаю Вам долгих и плодотворных лет, много здоровья и сил!
Я почти чувствую извинение, размещая свои фотографии среди таких великолепных деревянных моделей. Я пробовал деревянные модели, но не могу поддерживать интерес в течение нескольких месяцев, необходимых для проекта!
ICM 1/72 Зеехунд.
Подводная лодка ICM 1/144 Тип IIB
View attachment 244786View attachment 244787
Звезда 1/350 Князь Суворов.
Море — это глина DAS, наносимая тонкими слоями (между нанесениями дайте высохнуть в течение дня или около того), чтобы минимизировать растрескивание, затем запечатывается разбавленным ПВА и окрашивается — я использую исключительно акрил, аэрограф для грунтовок и базовых покрытий, ворсистую палочку для всего остального. .
В настоящее время я работаю над Mirage 1/350 HMS Spiraea, но на данный момент работа застопорилась...........
Одно могу сказать: мне не нужно много места для работы или демонстрации моделей кораблей!
Дэйв
Привет, Дэйв!! Ваши диорамы и корабли прекрасны. Очень интересно... Вода как настоящая! корабли выглядят как настоящие! Очень впечатляюще, очень круто!
Это сабвуфер МикроМир 1/144 Голландия А класса.
View attachment 244894View attachment 244895
Сложнее всего разобраться: эти субмарины находились в воде очень низко, и кажется почти кощунством отрезать 75% корпуса, чтобы довести его до уровня «ватерлинии», а он все еще плывет слишком высоко! Фигурки представляют собой 1/144 (1/150) железнодорожных пассажиров с куском пластикового стержня на голове в качестве кепки и соответствующим образом раскрашенными. У этих штук был экипаж из 8 человек, поэтому большинство находится на корпусе (свежий воздух!).
Оригинальная Holland I была построена в 1901 году и стала первой подводной лодкой Королевского флота. Он погиб в 1913 году, когда его отбуксировали на металлолом. Она была обнаружена и спасена в 1982 году и сейчас выставлена в Музее подводных лодок RN в Госпорте, Хэмпшир, Великобритания.
Дэйв
Мой первый проект — Спасение HMS Victory.
Это моя первая сборка корабля, комплект Revell Victory, который я собрал без каких-либо серьезных размышлений или предварительного опыта. Пластиковые паруса сломались и теперь бесполезны. Я стремлюсь искупить свою вину, выполняя достойную парную работу. Сегодня сделал грунтовку, пара кусочков отвалилась! Я собираюсь начать методично рисовать ее на следующей неделе. Что касается такелажа, то он меня пугает!
Большое спасибо за поиск
Привет! Нет смысла чего-либо бояться! Такелаж или паруса, пластиковая замазка. Никто не будет вас судить. Они могут вас поправить или дать совет. Вы можете и должны ошибаться. Ваш корабль выглядит очень хорошо, но предстоит еще многое сделать. Сформулированы пожелания! Егор!
Hello! There is no point in being afraid of anything! Rigging or sails, plastic putty. No one will judge you. They can correct you or give you advice. You can and might make mistakes. Your ship looks very good, but there is still a lot of work to be done. Wishes have been formulated! Egor!
Дорогой шота70
Я не говорю и не пишу по-английски.
Перевожу через Google переводчик.
Я веду журнал строительства на сайте Koga, на который я дал ссылку.
Я не знаю, будет ли понят перевод моей работы, сделанный гугл-переводчиком.
Вести два строительных журнала мне будет сложно.
Вы можете наблюдать за моей работой на Koga и переводить любые выпуски. Это будет так же, как если бы я это сделал.
Я хотел бы поделиться с вами некоторыми работами и идеями, но это может показаться глупым. Некоторые аспекты имен Google не переводит должным образом.
Мне очень жаль, и пожалуйста, поймите.
Сам использую опыт своих коллег с Коги и других форумов.
На данный момент у меня нет мотивации продолжать работу. Я ищу.
Добрый день, Артур! Я не очень давно на сайте SOS и не просмотрел все журналы и издания. Многие моделисты публикуют здесь свои работы. И ни в одном случае я не видел, чтобы кто-нибудь из участников сайта SOS сказал, что «это глупо» или «зачем ты это делаешь»… Я просто не знаю таких примеров. Здесь могут поддержать, дать совет, как... Не стесняйтесь поделиться с нами. Ваш корабль или модель его части красивы и интересны! Никто на этом форуме не скажет вам ничего грубого или оскорбительного. Любое моделирование – это часть моделиста. Здесь все это понимают! с уважением и наилучшими пожеланиями. Егор.
Good afternoon, Arthur! I have not been on the SOS website very long and have not looked through all the magazines and publications. Many modelers publish their work here. And in not a single case did I see anyone from the SOS site say that “this is stupid” or “why are you doing this”... I just don’t know of such examples. Here they can support, give advice on how... Feel free to share with us. Your ship or a model of its part is beautiful and interesting! No one on this forum will say anything rude or offensive to you. Any modeling is part of the modeler. Everyone here understands this! with respect and best wishes. Egor.Cordialità...
Hello everybody, pleased to met you all. I’m new here and I’ve spent some days to snoop all around, I’ve seen a lot of beautiful works from many of you, so I think it’s right to present myself showing some pieces of my collection too.
They are not professional models, forgive me also for the low quality of my pictures taken with a smartphone, but they are made with heart.
Now I’ve just opened a new building that is Soleil Royal scale 1:70 from DeA kit, and this time I’d like to try to make a premium model out of this kit. Therefore I will need all the help any of you expert are willing to give me. I will open a blog about the building of Soleil.
Thank you and good look
In order of appearance:
Bounty scale 1:50 from Amati
Royal Luis scale 1:90 from Mamoli
Sovereign of the Seas scale 1.74 from Mantua (in reality this one should be the Royal Sovereign that is a different ship albeit similar to the Sovereign)
Lots of rigging!
Я очень рад, что вы показываете нам свой реальный проект. И я еще больше рад видеть еще одно рабочее место, такое же грязное, как мое. ;)
,," это творческий беспорядок!
Hello fellow model makers!
This is my first post here in SoS. I am currently working on my first scratch build project - Golden Hind. I am using Aeropiccola plans as basis but making quite a few alterations and deviations - consulting other plans as well as other build logs etc. The below are couple of pictures that would give some idea on my journey during the past year.
Hallo @Rock_from_Korea
We wish you all the Best and a HAPPY BIRTHDAY
click the pics for full-size versions...
Pride of Baltimore, 1981, 1:20 scale RC working model (build log on my web site - see signature)
Free-sailed in 2019, now installing sail controls I hope will work, and making 3D printed items such as guns
Constellation 1856, 1:36 scale RC working model (build log here on SoS - see signature)
Sailed under RC, jury-rigged several time, last in 2019. Currently adding details and 3D printed items such as pivot guns, helm, hammocks, boat fittings, crew, pin-rails, etc.
Macedonian 1812 1:36 scale RC working model (build log on my web site - see signature)
Floated for the first time in 2019. Currently sitting on a shelf pining for attention, and appearing in photos of the other models.
My actual build: Bomb Vessel Granado Cross Section 1:72
Check it out here: https://shipsofscale.com/sosforums/...on-scale-1-72-pof-kit-by-miniature-arts.12365
Cheers
Dirk
Hello
I sold the Adolph Bermpohl and the Vegesack again. I have so many other projects and since I have no real personal connection to Bermpohl, I decided to sell them. Bought for 40 euros, sold again for 250 euros.
This is my first large project: the HMS Revenge. I could not bring myself to cover the wood... either with paint or paper decals. I took the liberty to improvise with wood only... mostly walnut strips, walnut/maple and feathered walnut inlays.
