Due to the fact, that Dirk was not metioning it..... It is the mortar of the Caf-section-model kit of the HMS Granado, POF in 1:48Looks good, what scale you build it?
A nice completed Le Mirage. I like the clear looking wood. Almost like mine, just with clear varnish.I have since corrected this and I actually completed the model. I don't have access to good photographic equipment so I took out my old phone and here is the completed model.
Hello, the tomone hinges are projected for that position (agugliotti and female) ThanksRussian Schooner Polotsk. 1/72 - Rigging progress.
Dirk
I haven’t found where to enter my model currently under construction either.Could be the thread is hard to find.
Click on your pic/icon at the top, then choose 'signature' and type in your completed stuff there, then saveI haven’t found where to enter my model currently under construction either.
Hallo @mikmaddenHi Shipwrights,
I am new to the scene, and have started with a 1:65 Black Pearl kit, although my kit seems to be a copy of the full ZHL kit...
Hallo @AlanJI'm building the IBG 1/700 scale Royal Navy destroyers assigned to the Polish Navy in World War Two. So far the three Hunt class destroyers have been attempted. There are four models because I repeated ORP Krakowiak ( front and rear) after research showed some flaws in the model. I also added metal gun barrels, PE doors, brass mast and got a little more ambitious with the rigging.
Here is my Bluenose II "build log". I started this build on June 4th. This is my first build. I added the deck by slicing a very thin - I guess it was a veneer? I sanded it down. I will fix the bow. It's not broken. I am just figuring out how to make it curve. I will also fill in the area under the stern where it curves to a point.Dear friends,
you do not want or you are not able to make a complete Building log - f.e. not enough time or by other reasons......
Every model is worth to show - even without a detailed building log
There are a lot of members out there, which would be interested to see on which project you are working
This topic is for everybody who wants to show his/her project,
in between status or finished,
kit - scratch - plastic - card - tooth-sticks ......
complete view or in detail
-> with one or even more photos
Share your project with us and show your model in one post inside this topic
Please write only some words about the model - f.e. name of original ship, scale etc.....
Many Thanks in advance
BTW: You can also show your model, if you are already making a building log - than please add a link to your log
