Great work Johan, I can't wait to see the overall effect of this lighting once your model is complete![]()
Nice to see that the lights have been given a good destination
They give nice light for the very small light
@Nomad , @Henk Liebre and @Heinrich: Thanks for the positive feedback! And again a big thank you for the set of lights, Henk. I have been close a couple of times to give up on the idea of adding lights, but in all honesty, I couldn't let you down.Ik ben benieuwd!
Hey Peter,Hi Johan. Back on stage and saw your lightning progress. It gives your BN and your skills a new dimension. And it is a challenge to hide all the wires. I'm really curious what the outcome will be.
Hello Johan, Nice work on your Led Lighting, it all seams like a lot of work now but the end results will be very pleasing. I am in the same boat now, installing my Led Lamps in the bow section. I can not seam to find a lot of time these days to work in the Old Ship Yard, there seams
to be so much else to do.
Regards Lawrence
A lot of work indeed and this afternoon disaster struck...Hi Johan. Back on stage and saw your lightning progress. It gives your BN and your skills a new dimension. And it is a challenge to hide all the wires. I'm really curious what the outcome will be.
Hello Johan, Sorry to hear of your troubles. Yes these tiny Led Lamps are vert tiny and very delicate, I normally handle them with silk gloves [so to speak]. I tend to use the shrink wrap only on the wire joints as I feel that the wires are much easier to conceal over the much larger shrink wrap. My 2 cents worth, hope this helps.A lot of work indeed and this afternoon disaster struck...
While permanently attaching the two focsle lights to the deck beams, I put too much tension on the wires, while manoeuvering the lights into the required position, resulting in a few of the wire connections becoming undone.![]()
So it's back to square one for these lights.
Now I'm following a process to try and not to add more connections, but instead "store" the surplus wire in a shrink sleeve.
Still, handling these tiny lights is "monniken werk" (monk's work) and I had to re-solder both wires to one of the led lights.
Thanks for your advice, Lawrence. Initially I was inclined to use shrink sleeves all over, but that would result in quite voluptuous wiring. What I'm currently trying is to coil the surplus wire and insert that into a shrink sleeve. The resistors are then also inserted into the sleeve as far as they go. That combination is then attached to the beam. I will upload a couple of pictures shortly, to illustrate my intention. Still looking for space thought; it is certainly not at a premium for this build, especially since part of the internal structure will remain visible.Hello Johan, Sorry to hear of your troubles. Yes these tiny Led Lamps are vert tiny and very delicate, I normally handle them with silk gloves [so to speak]. I tend to use the shrink wrap only on the wire joints as I feel that the wires are much easier to conceal over the much larger shrink wrap. My 2 cents worth, hope this helps.
Regards Lawrence
I've never read the word 'voluptuous' and 'wiring' in the same sentence.......Thanks for your advice, Lawrence. Initially I was inclined to use shrink sleeves all over, but that would result in quite voluptuous wiring. What I'm currently trying is to coil the surplus wire and insert that into a shrink sleeve. The resistors are then also inserted into the sleeve as far as they go. That combination is then attached to the beam. I will upload a couple of pictures shortly, to illustrate my intention. Still looking for space thought; it is certainly not at a premium for this build, especially since part of the internal structure will remain visible.
It's also very time consuming; thinking about possible solutions, trying to have a plan B, trying out possibilities, realizing some possibilities are not feasible and starting over again. Basically the past few weeks have been spend toying with the lights and the routing, but coming up empty-handed sofar.
To be continued...
There's a first for everything!I've never read the word 'voluptuous' and 'wiring' in the same sentence.......
Before I decided to take on the "Lights on in the Bluenose"-project, I didn't realize that the scale we're working with would be the complicating factor. Just how difficult can it be, just a couple of lights, in parallel, just a bit of soldering, install things in the hull, hook up to some power supply and voilà, let there be light.That is not "leuk" (nice) to read, Johan. The thing is that you are pretty much in unchartered territories here - but between Lawrence and you (and with the advice of Henk) I am sure you will succeed in the end.
That is a lot of work with those tiny and wires, Johan. Fingers crossed for you by the installing of those beams.Two beam assemblies with the focsle lights:
The wiring for the two nav lights:View attachment 312854
The surplus wire coiled around something suitable:
The coil bundled, ready to insert into a shrink sleeve:
Insertion in progress, nearly there:
Wire assembly ready for the next step:
Fwd wire assembly:
A lot of soldering steps further, dry fitted:
Based on my experiences with the first wire assembly, I have decided on multiple, separate wire assemblies. That means I'll have two more wire assemblies to make; one for the two fishholds and one for the aft cabin. Another consideration is to permanently install what is completed; I don't want to touch the wire assemblies any more than I have to. That would mean installing beams 12 through 18 and completing that area of the focsle/front mast as much as possible, prior to moving to the next wire assembly.
