YQ Bluenose Ted R
I kept the keel notch aligned in both directions. Also keep in mind there is a front and back to the pieces that make a total frame. You do not want to 'hide' any of the sanding or fairing lines, they are your guide. You may have covered up the one you show, not sure though.
I think all of the sanding lines are ok. I double checked ,I'm good. Thanks for looking out.
Spent the whole day working on the frames after building the fixture. Got frames 1-8 glued together. No char sanding or shaping. I'll start that tomorrow.17090761508621262576843272194906.jpg
I've seen treenails added to the frames on a couple of build logs. Are these installed on both sides of the frame. All the photos only show one aspect. Are the insides ( where the fresh face one another) finish sanded prior to glueing to the keel.
I am confused on a frame building detail.
For vertical alignment of the forward and aft frame halves. Is the alignment point the keel notch or the lower deck level.
I see that you found your pace to make the frames, Ted.
Perhaps this pictures will help you a bit more.
The drawing of each frame shows the position of both. The two recesses, where the frame will later fit into the keel, are flush with each other. With a flat bottom. Also at the bilge, both parts align flat to each other.
In some of the build-logs you can see that some of us used a small piece of wood, exact the size of the recess:
When you build the top and the bottom part of each frame separate, you get 2 fragile 'spider legs'.
On this page of my build-log a showed step-by-step how I build the frame up, to get a nice alignment:
--> Frame Step-by-Step <-- (click)
Perhaps a bit (too) much information, but the proper alignment of the keel and the frames is crucial for the later result.
And above all, keep asking questions if something is not clear. There is only 1 stupid question: that is the question not asked.
I have adopted Heinrich's and Peter Voogt's build log essentially as a practicum. This build would be impractical without the assistance of SOS and it's members.
Started keel assembly this AM. Planning on a full day of fun.
Btw, note the glass building base recommended by another member. (I'm sorry I forget who/m).17091363108327324125948159413172.jpg17091363552854434797155144497796.jpg
Btw, note the glass building base recommended by another member. (I'm sorry I forget who/m).View attachment 431357View attachment 431358
That’s looking good, Ted.
PS: I don't have all the wisdom either, it has gotten ‘out of hand’ sometimes. ;) Please look also at others. :)
Following Canoe21 advice to get the glass plates has turned out to be doubly helpful. Just added a second glass plate to the top of glued parts ,10,14 to assure a flat assembly. I see this being useful in the future where others have seen warping on placement of the keel cheeks.17091424322012037145786324436199.jpg
Parts 10-15 arrived on a highly contrasting color from the earlier keel parts. I don't know if it's water staining or maybe some type of burl. However, is this going to be a problem? Any suggestions? Should I get them replaced before proceeding?
The bottom 3/8" of the keel and the stern post is all that will be seen, and not even that much if you decide to paint the hull on its color scheme. Well this is true for the planked side however the on the exposed rib side it will all be seen so maybe you can blend it by sanding I don't really know. I do know pear wood can still be very attractive even with uneven shades next to each other once it is sanded out and a poly coat matte finish applied.
Plus in real life chances are that the keel parts would not have been made from the same tree and might have shown different grains and different shades.
I'm going to paint one side. Want a clear natural finish in this side
This really took the wind out of my sails. I can't imagine spending countless hours trying to create a beautiful model and have one part that is wildly discolored.
I checked Peter Voogt's build log and nothing like this. (His model is #10; mine is #11. )
I sanded but practically the same. The discoloration is in the wood. Not surface.
Hi Ted,
To get an impression of what the combination of different wood parts might look like later, I slightly wet those parts during the build with a damp cloth.
Perhaps the dark distortion then looks slightly less dominant.
There will be parts added on both sides, 17/18/20/21/22. Place them dry-fit and see what it looks like.
Only a smaller triangle in the lower corner of the deadwood on the non-planked side will be in view.
Hi Ted,
Thank you Peter. I may be overthinking the situation. I'm so committed to building a really beautiful model like the others I've seen on this site. At this point the discolored wood would be fairly easily replaced. My lack of experience creates uncertainty.
I stained the non-painted parts with a reddish (cherry-colored) stain. This for the most part evened-out the differences in the wood colors.
Yup Ted I forgot about the veneer overlay which will indeed cover most of what you are concerned about. Could be why YQ wasn't concerned either. Do be sure to maintain the tightest joinery you can, you will be amazed at what you have to deal with if you don't.
