- Oct 1, 2023
![](https://shipsofscale.com/sosforums/styles/default/xenforo/ranks/06chiefpettyofficer.png)
I think you might have something there.
What brand of stain do you useI used undiluted stain and a semi-gloss varnish, water based.
Stain has to be applied very carefully to ensure even distribution. Often two or three layers are necessary to obtain the required result.
I agree. I'm so disappointed.Good afternoon Ted. Little by little she is coming together very well. My personal preference with poly /stain is to go for a clear Matt option especially if you have that lovely pear wood to show off…....as you say personal preference. Cheers Grant
A Dutch brand, probably not available in the US.What brand of stain do you use
Ted
Can't help you there, I had little to no issues with bonding, but if you used poly on top of the stain you might run into this issue.I'm at a total loss. Testing the water based stain for being able to glue over it failed.
I used minwax water based poly stain. I want to staina d finish the lower Deck beams and frame interiors prior to installing the finish deck. Access is already hampered.
What brand stain is safe tous
Please help.
Ted
For me it is clean: don’t stain the parts where you still have to glue.I'm at a total loss. Testing the water based stain for being able to glue over it failed.
Please help.
Ted
Thank you. I'll look at itIf you're interested, post # 230 from my log describes what I used for stain & topcoat as well as how I used it.
PS. As personal insurance to myself I never stained, or matte coated anything until I was finished with the glueing. Not an easy thing to do but it is doable.
Thank you.For me it is clean: don’t stain the parts where you still have to glue.
For my build it was more the clear, I use linseed olie.
So, about other types I can’t give you a advice.
Good afternoon Ted. I am with Peter. I sometimes have to sand a small area with a tiny sanding stick if I have put poly on before and need to glue. CA glue(gorilla) does hold however it can be messy if one gets it wrong. Cheers GrantFor me it is clean: don’t stain the parts where you still have to glue.
There is no better reason for the continuing of your build than what you just wrote, Ted. What a grand gesture to your Admiral.My audience besides you gentlemen is my wife. She doesn't see. The details to the same level we do. My life expectancy is not that great at this point and my better half sees that s model as a memorial of sorts she can associate with memories of me.
That’s a driving force like no other…my better half sees that s model as a memorial of sorts she can associate with memories of me
