HMS Ontario 1780 scale 1:32 POB full version
Great progress, Zoly! Thumbs-Up I am guessing, that novice model builders will have the same question as myself: How do you manage to bend the planks along the edges? Did you make a jig or bend each plank individually?
Here is an earlier post on edge bending
Hello guys,I need a little help,I am looking for a tutorial how to cut gratings ,I seen it somewhere when I did not need it ,but can’t find one now,thanks!
I have seen photos of basic method, depends on if you are using a mill or saw to make cuts.
you take a stack of thin strips and you can make longer than needed and glue ends together (cut off to release each board when done), then using table saw, set fence and make cuts to match wood width and move over for grate opening size and repeat until other end is reached. Mill method is same, done from top side with narrow mill bit.
