You probably have an old version of frame 9. Donnie can make you a member of the group build. This is a copy of the latest revision of frame 9, sorry you had a problem.Hope someone is still reading this thread. I came across this project by mere coincidence. I stumbled over a post with a link to download part 1. I removed the last part of the URL and since directory browsing was allowed I downloaded the full set. A few days later I read another thread in this group and realized that I actually had to fulfil some criteria in order to get a download link. Well, I may not fulfil the criteria 100% yet but I anticipate I will soon. I do agree to the terms that applies once the plans are obtained. Hence I hope I’ll be forgiven for downloading prematurely?
Provided there are no objections I would like to try if I can build the 1:32 version. I will probably use only types of wood I can obtain from the local building supply store as it will be my very first build and not unlikely ends up in the trash bin. It surely doesn’t look promising from the start. I have already run into the first “opportunity” before I have even started:
I printed out the building jig set to ‘Actual size’. Then I checked the length of the 10’ scale. I measured slightly over 95 mm. I’m not familiar with the imperial measurement system but I believe 1 inch = 25.4 mm and 1’ = 12’’, right? 10 x 12 / 32 x 25.4 = 95.25. It seemed to be spot on so I continued with printing the frames. When I came to frame 9 I noticed a metric scale so I checked that one as well and then the shit hit the fan. It is supposed to be 240 mm long but I measure it to slightly over 255 mm which is >6% off. What have I done wrong?
I guess Poul will have the group build symbol added to his signature when he starts a build log.He is already member as he can post here
Sorry for being persistent pain in the b... The issue has nothing to do with the printing. If you look at page 2 of frame 9 in your post (before printing) the 10' scale clearly corresponds to 90 mm. Now, 10' = 120 inch, right? 120 dived by scale 1:32 = 3 3/4 inch (which btw is also exactly what I measure on my printed copy ) 3 3/4 inch converted to mm for all I know = 3.75 x 25.4 = 95.25 mm (not 90 mm).Hi Poul, I checked the scales with AutoCAD, and they are ok, if you are taking your measurements on a paper copy it may not have been printed correctly. If you had the drawings printed on the same printer at the same time and use the patterns the model should go together.
Lets wait for Donnie ,I think you have a non revised version of the plan setSorry for being persistent pain in the b... The issue has nothing to do with the printing. If you look at page 2 of frame 9 in your post (before printing) the 10' scale clearly corresponds to 90 mm. Now, 10' = 120 inch, right? 120 dived by scale 1:32 = 3 3/4 inch (which btw is also exactly what I measure on my printed copy ) 3 3/4 inch converted to mm for all I know = 3.75 x 25.4 = 95.25 mm (not 90 mm).
Anyway, I'll just ignore the metric scale.
//Poul
