She is a bit shy, but will answer here soon.
yes,they would get together with Olga@Bonden Why not invite your girlfriend to join the SOS? Then we all have a chance to see her Victory build log. I think this is a great idea, what do you think?![]()
As my Mercury is going to be a diorama also, I’m planning just the same. I’ll use thin wire tucked in with the bolt rope and sail to produce the fuller shape.Thank you, @Uwek
But there is a problem - gravity.
Because there is no wind, the sail is always pulled down. The bow remains, but the sail is not pushed out as nicely as it should be. In the
third picture the bow is only so beautiful because I blew hard against the sail while taking pictures.
Here I want to try spring steel wire. I hope the Google translation is so that you understand what I mean by spring steel wire ...
I take this wire as a sheet rope and hope that it will be able to push the sail out far enough. I ordered the thin spring steel wire today. I will report.
