Hello Everyone
Time for a decent update. Yesterday I had the day off and had (by my slow standards) a very productive day. So to kick off this post just a status quo picture of where I am at the moment before work commenced.
With my replenished wood supply from Kolderstok having arrived, it was time to complete the coloured wales on the starboard side. I have to point out that me having to order extra wood is by no means an oversight on Kolderstok's part. I have purposely used the 4mm walnut strips for certain parts of the build where I should have used basswood.
With that done it was time to remove the protruding bulkheads from the deck.
During the installation of the wales, great care was taken not to apply glue to these parts of the bulkheads; so removing them was a simple task by using a pair of pliers to snap them off at the base. Even so, it was quite strange breaking something on purpose after you have taken such great care during the building process not to.
The remaining stubs were simply sanded flat to deck level. Next the waterway was constructed from two 4mm x 1mm slats glued squarely to each other and then painted black. These two strips were then glued into position on both sides.
The waterway is indicated above. Also visible on this photo are the coloured (maroon and yellow) wales newly fitted to the starboard side.
The idea now is to glue 2mm x 3mm strips (indicated by the blue arrows) on top of the waterway and against the inner sides of the wales to act as bracing and as a start for finishing off the interior part of the wales. I say "start" because these slats will have a horizontal 4mm plank glued on top of them with more vertical bracing on top of that. Finally, the whole assembly will be finished off with another horizontal plank on top of those. If it sounds complicated; it is.
 Finally the sides will be painted black on the inside.
However, I am still contemplating on where to install my cannons and as this deck remains a candidate, great care will have to be taken with the positioning of the vertical slats. Hence, I decided to keep that for a later stage.
Next I finally placed the half deck into position and glued the grating in its cut-out. The gratings: Trial and Error - far more "error" than "trial". However, I finally had something that I was happy. I stained it with the Dark Oak water-based stain that Hans has so kindly provided me with Free of Charge and was pleasantly surprised at the result. At first I thought it was far too dark, but seeing it on the ship - especially after I had planked the Half Deck - changed my mind completely.
Half deck with grating and the two black half-walls are installed. As can be seen these are also constructed of overlapping planks in clinker-style.
As it was not yet bed-time, I placed the walnut border around the front deck cut-out and started to commence with the planking.
As I was very pleased at how this turned out, I continued planking ...
And when dawn broke this morning ...
Voila !!!
Thank you all for following the build, all your positive comments and suggestions. Hans says his kits have a "gripping factor". Yesterday, for the first time - in a very long time - I lost myself in this build and became fully immersed in what I was doing. A rare, and most pleasant feeling.
Keep well everyone and take care.
Friendly greetings - Heinrich
