Looking forward to your photos, Dave.
Herasee !!! Burn the heretic!!! First it's fictional, then you have the audacity to change it???Thanks, Gary.
This "Independence" is a fictional vessel so I decided to rename this schooner "Clio" after the Muse of History in Greek mythology. My friend Mike Shanks was able to laser etch some ebony I had on hand. I then painted the etched name using white acrylic paint. Sanding the face with a 220 grit sanding block took care of any excess paint on the name plate. I then glued the name to the transom.
After a lot of thought I decided to include quarter badge windows. This is a small, simple ship so I opted out of all the elaborate carving and went with a simple 4 pane light that Mike Shanks cut out for me in boxwood. I took a cue from Dr. Clayton Feldman in his "Lexington" build and added a curved rain diverter and sill, both of which stand proud of the window. Simple molding strips form the sides of the framing. All these parts are of ebony.
I am learning by just closely seeing the work that you do. Thanks for the excellent photos of an excellent build. PT-2Thanls so much for the kind words and the "likes" guys!
The anchor stocks are really looking better - they were too thick in the beginning, so the ratio between length thickness and depth was somehow incorrect.Even though I used the kit parts as templates for my remade anchor stocks (using swiss pear), I really didn't like how they turned out. The stocks are too clunky and I didn't like the reinforcing band placement. So I made them over.
Much better, I think!
View attachment 178136View attachment 178137
I agree here with you - it is different, but you can concentrate with your view on the hull form and the deck installationsSometimes I think a modeler is cheating when making a stub mast model with no rigging ...
Nope. In many cases the rigging - because of the height of the masts and large sail areas - dominate the overall effect when the ship is viewed in full. A model which only features stub masts places the emphasis on the ship itself. So, it is a question of horses for courses. I am with Doc on this one.
