Sorry, it is a stain..What exactly is the Golden Oak - is it a stain?
No problem, it was my bad...The manufacturer usually source different materials over the years, so the instructions have pictures with old style grating...
It is still there, just hidden thru picture view..Looks great! I like your way of making eyebolts. I'm always lazy and use ones from kits.
I noticed that there is no hole in your stem. There has to be one for bowsprit lashing. You had it in your previous pictures.
I measure the outer dimension of the pipe and used it as inner radius for a loop (kind of in the picture). This was used to choose a size of the drilling bit i used to make few loops. Loops were soldered and flattened with small hammer and anvil.I like your metal covers on the inside! Great idea. I should start doing that too. How do you determine the radius of the loop?
Hello, Moreplovac. When you flatten the hoops, the inner diameter will make it smaller. Is this correct?I measure the outer dimension of the pipe and used it as inner radius for a loop (kind of in the picture). This was used to choose a size of the drilling bit i used to make few loops. Loops were soldered and flattened with small hammer and anvil.
If you are careful and try to hit the outer side of the wire (ring) you might lower the result of diameter shrinkage..Hello, Moreplovac. When you flatten the hoops, the inner diameter will make it smaller. Is this correct?
