Sure thing, Daniel. Tomorrow I'll start milling notches in the second beam and take few pictures.Very clean job!!!
Please show how you use the MF70 for your parts. I just got one 3 weeks ago and I would like to see how others use it for their models. Will open my mind to all the possible uses of the MF70.
Thank you !!!
Daniel
I even use it as a micro spindle sander for sandings inside arches , works great.Very clean job!!!
Thank you !!!
Daniel
I wonder if the bearing in a small drill press are stable enough to do the same. . . problem is that the handle to bring the bit down would need some rigging and a foot treadle or device to lock it in place for the sanding. Any recommendations???? Rich (PT-2)Nice !!!!!!
Thank you
Daniel
Rich, I'm not machinist, but as I understand drill presses are designed to handle vertical, not horizontal forces. Since pieces in our hobby are quite small, it might be worth trying.I wonder if the bearing in a small drill press are stable enough to do the same. . . problem is that the handle to bring the bit down would need some rigging and a foot treadle or device to lock it in place for the sanding. Any recommendations???? Rich (PT-2)
This is how I used Proxxon MF70 today to mill notches in beams and circle in mast partner. Unless one has CNC, the most important part would be to mark piece as accurately as possible. Beam was laid flat on xy table and clamped, milling bit was brought down to the surface of the beam, vertical dial set to 0 and then dropped by 1/32" (0.8mm) since that is the depth of the groove. Then carefully start milling:Very clean job!!!
Thank you !!!
Daniel
Used the same setup for sanding frames on La Belle. This little milling machine is so versatile. I've had it for the past 14 years and still works like Swiss clock.I even use it as a micro spindle sander for sandings inside arches , works great.
I like to see how some needs are met and resolved in such a careful manner with precise outcome. Rich (PT-2)Dear Gennaro
you are doing great job and the results are very beautiful
Once you are done with milling, corners need to be squared up (I used 1/16" milling bit):
Circular opening on the foremast partner is 9mm in diameter - I wouldn't use 9mm drill bit to make it. Instead, here is the setup:
After several shallow passes you'll get the opening. Most likely I'll have to repeat this again once I get to masts to make sure that rake is correct.
Many thanks everybody, for all the likes and interest. Happy Saturday!
Thanks Daniel, much appreciated.Looking great !!!!!
NIce, neat, and uniform work well done. Rich (PT-2)Conquering deck one notch at a time. Never built model of a french ship before. Quite a carpentry. Carlings framing the fore hatch are not finished yet. Dove tails need to be milled for ledges. There she is:
Thanks for all the likes and interest.
