Getting close to finishing the cat davits for the anchors...have to drill holes for pulleys and add additional pulley arm. It’s not deep enough for the pulleys they provided, so as usual some modifications will be in order! Then I can add pulleys and clear coat everything. Will also go ahead and put on any cleats and eyelets needed for rigging in the bow area.
The foremast carling worked out nice. I test fit with foremast as it has to be sanded to match dia and angle inside. I also had to notch the railing at the bow for those to attach because of the steep angles on the railing.
