Crawling forward. The stern structure was partially assembled and test fit onto the hull frame. Before the side pieced are attached to the stern, the frames of the structure will be narrowed to a shape closer to that appearing in the Lely portrait of Peter Pett, also using measurements taken off Nigel's photos above as a guide. All of the individual magazine packs for the kit were opened and the instructions placed in binders on the bookshelf for reference. After looking at the cast metal decorations, they appear to have fine detail, mostly because they are a bit smaller than I expected. Their size indicated that few to none of the beautiful Amati cast decorations will fit on the DeAgostini model, which is disappointed because they are high quality. Since I also have the Amati plans, I wonder it I have the patience to make a second SotS model using them, when the DeAgostini model is finished? Some shortcut were noted in the rigging instructions while glancing through the magazines. The standing and running rigging are largely simplified, there are no triple parrels on the larger yardarms, only double rowed ones, and all the leech lines and bowlines are conspicuously missing, as are the nave lines for the parrels.
