While I'm waiting for more information from Nigel and a bunch of balsa blocks that were ordered, work on the launch was started. It's a basic frame and planking kit. Once the balsa arrives it will be used to fill the space between frames below the lower gun deck to help control the bends and prevent flat spots in the first planking.
Kurt
The Lely portrait only shows the stern which would be all black if following the same scheme of later 17th Century ships.My interpretation is that "only colour used was black"only refers to painted areas.It doesn't necessarily mean the upper hull didn't have areas of unpainted Oak.
No conclusive information is available,but I am pretty confident blue didn't feature as it does in Sergal's design.
Kind Regards
Nigel
Kurt
Kind Regards
Nigel
Thanks Nigel. Just tryin to put the whole color question in perspective. The model would look better with unpainted wood on the sides, and I'm leaning that way. No red strips or railings though. They look nice, but I can't find any source for them.
Kurt
There is a painting of the ship under sail with the red railing panels.The red areas were quite common in the second half of the 17th century amongst English vessels.Several paintings of the period show these on various English ships of the line
Regards
Nigel
Kurt
Regards
Nigel
A painting of SotS with the red rails? Where? I'd be interested in posting it here, and dating the painting to see if it is older than 1660.
Nigel, how do you do your trenails and iron bolts on the hull? They show up we even against the black painted planking.
Kurt
The treenails on the hull are 0.4mm holes filled with wood putty.The black areas are not painted,I used "planks" of black marquetry veneer with 0.3mm brass wire to represent the fixings.
Regards
Nigel
Hi Kurt
No hurry. My work on the frame is proceeding as information allows, and there's no rush. I estimated the change in rudder post angle taken from measurements of your photos, and have penciled in the next change, which is that transverse sweep of the upper transom from a double curve to a single one, seen below. When narrowing the upper frames, will the change in dimension require new upper frame support pieces, or just a thinning of the existing ones?
I noted in your build log that to planked the entire outside of the hull and then worked on the decks starting at the bottom. I can see that way any vertical repositioning of the gun ports can be reflected in the decks, after mapping the wale and gun positions on the outside of the hull. Seems like a logical progression. Like you, I will have to excavating the frame structure below the lower deck, and let the exterior of the hull dictate the position of the interior structure. The first step is establishing the shape and form of the exterior, one feature at a time.
Upper stern sweep proposed changes
Sternpost increased angle
Sternpost angle changed, with frame support jig changed to match upper section of sternpost
Proposed change to increase angle of stern by extending poop deck 7mm.
Proposed changes to gun ports and upper transom sweep
This modification will also be incorporated
Nigel, I could use these dimensions when you get a chance. More requests will follow, and I am very grateful for your help.
Hi Kurt
Dimensions as requested to your picture to the outside of the planking.The bottom dim is to the outside of the planking, not the wale.
Top 79mm
Middle 90mm
Bottom 121mm
Regards
Nigel
Kurt
If I remember, it may have been the second to last bulkhead is dubiously narrow around the lower gunlock causing a dip.I packed it out slightly with scrap before planking;)
Regards
Nigel
