Kurt
It will be frame -1 from memory.Try a plank against the frames and you will see what I mean unless they revised the shape.My partwork was the first batch.
Your pencil lines look to represent what I did.I had full planked the hull then made the changes.I gutted the hull then pulled the sides in to achieve the same shape.The hull form is ok midships, it was just the stern that needs flaring in at the top.You will need to fair the frames in such a way as to blend these alterations to the midship shape.Lots of gently sanding and a fairly stout strip as a guide will help as there is a very shallow radius in plan.
Regards
Nigel
Regards
Nigel
