Sailors need something to eat and so I started with the kitchen. First I need a cooking pot.
The lathe laughed once when she heard about it.
1 st try made of brass.
First touch briefly with a center drill. With brass not necessary, with copper absolut necessary. Otherwise the small drills will move and break.
Then drill deeper with a drill bit. This is where handles will befixed later.
2. try to make a pot out of a tube without a lathe. The pots were made of copper and I did not really like the color of the brass pot. First the pipe has to glowed with a burner to soften it. Then expand the tube with a mandrel and a hammer.
Solder in the lid. The bottom stays open and gets a wooden core after soldering.
After the silver soldering the pot looks bad. Put it in vinegar for a view hours and polish it.
Put on the fittings and age a little and two pots are ready.
With best regards
Thomas
Some modelers have been touched with the Magic Wand of Creativity. You are one of those !!!
Thank you for showing how you do those creations!!!
Cheers
Daniel
