Planking, planking, planking...
I added the frames for the gun ports when I completed the first layer of hull planking. I didn't do this because I thought it was a good idea (versus after the second layer of hull planks like I see for most builds) - I did it because my cutouts in the primary hull were so bad that I needed to correct some size / shape issues before adding the second layer.
Because the frames were already in place I needed to be quite careful cutting back the openings. I will need to do some painting touch-up but so far so good...
Planking, planking, planking, planking... (and I still need to do the other side)
Thanks for checking in!
