Hey Jim, how do they hold planks together if there is no underlying frame to support them? Am I missing something here?Those might be just treenails (not bolts) and used to hold planks together...
**VIEW THREAD HERE** |
Hello Chris, This is clinker style planks. Both planks bolted to a frame's part (floor timber or first futtock) but between the frames, they 'clinched' using clinch or other fastenings by mean. However, this is not my statement, it is rather assumptions based on below images.Hey Jim, how do they hold planks together if there is no underlying frame to support them? Am I missing something here?
Ahhh... now that makes sense. Thanks for explaining to the relatively new ship builder.Hello Chris, This is clinker style planks. Both planks bolted to a frame's part (floor timber or first futtock) but between the frames, they 'clinched' using clinch or other fastenings by mean. However, this is not my statement, it is rather assumptions based on below images.
Just an idea in case you or others are planning to use bolt in the planks: I think I would mark the centre of every frame on a few of the planks - or at least on the keel.
Or maybe there is an easier way to mark all the bolt locations once the hull is fully planked?
Hallo my friends,Are you going to mark bolt locations on the planks Uwek ?
I have the same situation - only on some areas the clamps I have are working (partly), so most often I use also appr. 50% of the contact points with the frames with CA, and the other with wood glue..... this is now off course more problematic, due to the fact, that the interior planking is already installed.@Uwek How are you clamping planks 23 and higher to the hull? I am unable to figure out a good way, other than to use CA glue at several points and press it down by hand until it dries.
I will master the technique of bending the planks as I won’t go through the CA torture againI have the same situation - only on some areas the clamps I have are working (partly), so most often I use also appr. 50% of the contact points with the frames with CA, and the other with wood glue..... this is now off course more problematic, due to the fact, that the interior planking is already installed.
It is helping a little bit, to get the planks already in form of the curve necessary, f.e. with watering the planks .....
