I might add that laser cutting might not be much of a problem for POB kits. But, with small frame (rib) parts and the keel, then this is different. No complaints. I know that CNC is coming upon us, but not everyone has or can embrace the CNC. Also, laser cutting is a science in itself such as maintaining equipment and making sure the laser beam is focused as it should. Then the thickness of the material has a lot to do with it as well. Thinner material is not going to reproduce an angle to the cut, whereas thicker material means more angle - it's all in the math of angles and such. The thicker the material, the wider the angle is going to be. Lastly, the position of the part that is being cut out. Just my 2 cents. It is what it is. Just have to work with what you got. No problem.
Thank you Donnie, you build many carefully than I. I build name is "HMS druid1776"Wang
I will move your images to the "SOS Scratch or Plans Build Logs" however, what is the name of the ship that you are building that you show the photos? I can help you start the Build Log TITLE.
Hello Donnie, You ack like you are a pro with your mill, as you have did a very nice clean job.The images now show that I used my Mill to square up the faces or edges of the Keel. There are three sections to clean up. It only took about 15 minutes per section to clean up. However, if you are doing something like this for the first time, I suggest that you plan ahead and go very slowly. You will notice that I use a block of wood under the keel. This block of wood is very important. I am able to use the block of wood as a flat support surface and at the same time the jaws of the vice keeps the keel locked down. However, this is the important point. You DO NOT want the PRESSURE of the down force of the Mill to push down on the stock you are working on. This is the purpose of the block of wood. You always MUST have a secure flat stable environment for Milling. Like I have always said, it takes more time to setup to make a cut than the cut actually takes. I am not being some safety geek. I am saying this as this is the proper way of doing things and you certainly do not want to damage the piece you are working on. You work with wood LIKE YOU are working with metal - SAME RULES apply !!!!
I am using a down-cut End Mill for wood use. The down-cut End Mill makes for a nice clean cut that will not fray the wood. The End Mill was bought from https://www.2linc.com/ Part # PWD2-125-1 @ about $15 each This End Mill should be able to fit on the Proxxon Mill as well. The shank is 1/8 inches (.125 inches) or 3.175mm
The last image shows a frame inserted on the Keel and the job is well done.
