Re: Royal William 1/48 scale
Hi John!
I use this liquid glass.
The lamp is made of brass and burnished. Then the openings were filled with liquid glass with a brush. Today smooth rolled glass is used. In the past the window panes had such bubbles. The windows of this lamp all have a closed surface. Only sometimes it looks as if there are holes in the pane, depending on the angle of view.
Old glass panel in the dining room cupboard.
With best regards
Thomas
I tried blackening the larger cannon but the results were not too good as you can see from the pic, so I made up a small jig to hold the large cannon, these are 65mm long, so I could drill the holes for the trunions.
Just to share something I discover to age the cannons....
try spraying this paint from about 40-50 cm distance. In very thin layers. Te result would be that the paint will land like a “dust”. And the finaL effect Would be something like this...ECBA3209-E8E2-4BD9-A82E-4F49CC73E436.jpeg
The dust will give you the impression that they were melt in “sand” mold as they were in real
Hi John!
With best regards
Thomas
Would be interesting to see if it stands the test of time and doesnt discolorizes. However I love the result, just perfect.
Hi John!
With best regards
Thomas
G'day Thomas, I have a jar of this that I use when building my tug boats, I didn't realise that it also was used for glazing, so i made a spare window frame a gave it a try,
The clear fix,
after one application,
another view, it looks different from different angles, i am going to experiment with it a little
bit to see if I can get it any better,
I was going to make my own mouldings, but I saw these brass ones at Cornwall Model boats, so I thought
I would give them a try,
and a few pics with the mouldings just held in place at the moment, they will of course be cut to fit to across the
ports etc,
I thought that for a bit of a change over Christmas I would do a bit more on my Royal William, as I have said
before I am not much good at carving so I will be adapting these white metal and resin figures to fit on the Stern,
I have quite a selection of them so I hope to come up with something that looks decent,
close up of one of the figures,
and a selection of cherubs and other figures that I have collected over the years, If I found something that I liked
I would make a mould of it and cast more,
An idea of how I would adapt them,
and with some of the scroll infils for the rails,
They are white metal so they are easy enough to cut and shape,
thank you for dropping in,
best regards John.
Cooked the Christmas Ham today, we are celebrating our Christmas tomorrow as our youngest son works in Age Care
and he is rostered on through the Christmas period, so all the family are getting together for lunch at a local restaruant,
and then coming back to our house for a couple of hours,
and a I made a berry Pavlova for dessert, maybe tomorrow or the next day,
Merry Christmas to all the Members of SOS and their Families,
best regards John,
I have decided that before attaching any decorative figures to the stern it would be best to finish off all the doors
windows etc, so i have started building the inner stern gallery bulkheads, this is the lower gallery one, got a lot of
cleaning up to be done,
and both the lower and upper bulkheads,
Next up I had to make the fluted mouldings that go by the sides of the doors and windows, the profiles on the
above plate were not large enough for what I wanted so I had to use one of my Artesania Latina plates,
The A/L plates do not have any timber support plates so I used the support plate from the Chinese set, I just laid
it over the top of the A/L plate and drilled four holes just like on the Chinese one, once I had the two wood
support plates bolted on everything was fine,
This is the result on two pieces of American Cherry Wood,
and just a mock up to show how they will be applied,
Just working out what had to go where and to make sure the spacing's were correct, as it was I had to cut the
plan and widen the width some more, also shows what I will be using for the top and bottom of the Fluted
mouldings,
all the parts now glued in place just have to give it all a final shaping
After the final shaping, I also had to cut a piece from either side of the end fluted pieces to get the Partition
to fit in place.
well it was time for a snack and we had the first meal served in the Captains quarters, a Meat pie,
so that's the bottom partition almost finished except for final adjustments when fitting in place, and the top one
has to have final shaping yet,most of these partitions as well as most of the exterior of the Stern area's will be
Gold Red and Blue,
2009-10-03 - USNA Museum - 081 - Royal William - 1st Rate 100-Gun Ship of 1719 (stern) - _DSC7...jpg
.This is the stern on the original model, I think mine is going to look a little bit different,;););),
I was a little bit worried about having to trim the end Flutes, but when I enlarged the original photo there are no end
flutes on either upper or lower partitions, the small arch that leads to the quarter galleries just but up against the rear
partition,
Thank you for looking at my build,
best regards john.
It looks great, thanks for the explanation and illustration of the work process, I just got it
This is how the gallery bulkhead will look, and I have also remade the entrance to the side galleries,
this is all the stock prepared for making the windows for the partition,
One window made and just sitting in place, I'm thinking of making them a little bit thinner,
I have re-cut some of the wood , might still go a bit thinner,
