Next step was to start rigging each shroud line working left to right so I could reach in to tie off. Being right handed it made the most sense.
i had to make this sub assembly on the shroud pendant pulley...weird stuff!
...then I had to tension one side and I hung some hemostats on the right side to keep tension and attempt to even them. In retrospect I should have glued the lines in the pulley and then done it...hindsight!
...as you see, after tensioning the other side with 4 pulleys, they are not the same height, but it probably doesn’t matter to anyone but me...lol
Strangest rigging I’ve ever encountered! One side has 3 pulleys and the other has 4 and they are connected to 2 pulleys going through 1 pulley! So one shroud line has 8 pulleys needed to tension! Madness!
moving on to the next line I had to tension one side first again...
then I tensioned the 4 pulley side and the last one was easy in comparison!
One side done...back to making pulley sub assemblies for the other side. All will have to be rigged with tension lines going the opposite direction (mirrored).
View attachment 204801View attachment 204803View attachment 204802
