I just bought a wooden box for them - you can see it under the head magnifier and open with the burrs@Uwek
I have the same bunch of milling bits. But i didn´t find any way to storage them, so they continue in the plastic bag.![]()
@steef, not too bad price for the small chisels, do you have a link to whore you buy these.
Little update to these knives. I used them now for a project and I don't like them.lovely topic. I like new things to buy and have. So I will show you mine
Yesterday I got these from Aliexpress about the 10 euro's, in a box including some sandpaper to sharpen them
they are great, already tested them. The smallest chisel is 1 mm
View attachment 216525View attachment 216526View attachment 216527
I was following mainly by the very positive experience made by Maarten.I'm curious, because it is watercolour paint for aquarelle.
That looks very realistic. You still can see the wood grainI was following mainly by the very positive experience made by Maarten.
After the lower transome parts dried the PS side is sanded to a flat surface. Next the PS wale is recolored with ecoline. Now I will prepare the planking above the wale. This planking will be yellow ocre, I color again with ink, dark yellow ecoline. The ink will keep the woodgrain visible...shipsofscale.com
Ecoline works great, it is also used by guitar buulders. you only have to be aware of the lower UV resistance for the brighter colours, but black is ok.That looks very realistic. You still can see the wood grain![]()
thanks for the tip. I used till now only Vallejo and extra water to keep the layers thin. Not on sculptures, just on wood. I only knew ecoline from aquarelle paintingEcoline works great, it is also used by guitar buulders. you only have to be aware of the lower UV resistance for the brighter colours, but black is ok.
For bright colours you can use aero colour from Schmincke, these are containing pigments.
Ecoline and schmincke are both a kind of ink, they penetrate into the wood. The result is coloured wood where you still see all the features of the wood itself.thanks for the tip. I used till now only Vallejo and extra water to keep the layers thin. Not on sculptures, just on wood. I only knew ecoline from aquarelle painting
This I can fully confirm in the meantime.Ecoline and schmincke are both a kind of ink, they penetrate into the wood. The result is coloured wood where you still see all the features of the wood itself.
