Paul,
not an issue hahaha.... your hull has been my guide - just as is - It will be super time consuming painting so many detailed colors on all of those figures - you are certainly up to those tasks. It will look excellent when you're done. The Artesenia guide is excellent. That kit looks to be very impressive as well.
Of the three ships that I have built (SotS) my fourth - though one was just a cross section - have not used any sort of hull planking sealer - did use oil on the current build in order to differentiate the planks, as you know.
With my Vasa I only did a sorta hull look from the museum - The issue was also that I had unknowingly chosen a Corel - way back when... Did bash the hell out of it however and added sails. But all the figures where all "out to lunch".
Cheers,
not an issue hahaha.... your hull has been my guide - just as is - It will be super time consuming painting so many detailed colors on all of those figures - you are certainly up to those tasks. It will look excellent when you're done. The Artesenia guide is excellent. That kit looks to be very impressive as well.============
Cheers,
