Yes I already didThese pulleys are already functional!!! I allowed myself a picture with a function. I would add more space for guiding the rope from the wheels. Green ...
I keep my fingers crossed !!!
I'm keeping my fingers crossed! You continue nicely and quickly. Take a look at Mati's photos again, these ropes are usually wrapped in a weak rope ..I started with the practise of grommets and eye splice. Some rope to get the knots. Never did this before. I think the eye splice (1) is correct, but the grommet (2) is not. I used the method @KUDIN explained. But looking to @mati.n his grommets they look if they made on another method.
Yes the rope must be serving, that is no problem I know how to do that. This post is about practise the knots.
Maybe I should need a little more practise doing.
This one is really good, I cannot even see the ends...Third attempt to make a Grommet, I think this one is good.
Doesn't get any better than this! What's the diameter?Third attempt to make a Grommet, I think this one is good.
Now I wil try to make it on scale for a block
See you later![]()
Diameter 15 mm, rope 2 mmDoesn't get any better than this! What's the diameter?
just one end is cut at angle to be able to form some sort of "tear shape".
I already thought so. Because I study your pictures and couldn't find the joint or the thicker parts where they are joint.Hi Stephan,
I'm lazy bastard, so my eye splices are simply gluedjust one end is cut at angle to be able to form some sort of "tear shape".
For 0,3mm, 0,4mm or 0,5mm ropes it's ok... hardly you can see the joint... you will need big magnification glass
If rope is served... and I need to do eye splice I'm doing the same, cut one end at angle and form eye, CA glue... and eye splice done.
...same story with blocks stropping (served or not). I'm cutting desire length of the rope for strop, micro drop of CA glue and connecting two ends to have a loop.
Most of the time I'm hiding the joint under the seizing
Splicing it's another art in our hobby... but I'm finding this to be reasonable only with thicker diameter of ropes.
Other then that I'm cheating
@Ondras71 - would you be so kind and drop the link for website with Batavia photos. Once I found nice gallery... and I've lost the link and couldn't find it back after some time.
Cheers,
Matt
