- Apr 23, 2021
XD I did it the same way you did.Looking good! One thing, though—are your gun carriages wider in the front than in the back? I did mine that way and was informed it was supposed to be the other way. It was too late by then; I was already committed.
Not a chance to correct that. For the next project, but for now im going with no cannons.
Going to make a little investigation about the subject.
Feel free to ask! this the place to solve those "kit" questions.Brilliant work, it looks amazing. I'm very new to building model ships and I chose the HALCON 1840 1/100 scale ship, but the instructions are useless they barely tell u how to put the hull and deck together, they don't tell u how to build the masts or sail's or how to set the rigging. I'm just about to attach the long 3mm piece that runs along the side of the boat where the canon's stick out and I was wondering if u have any suggestions on how to bend the piece of wood without breaking it as I need to get them on so I can start planking the hull
For every piece of bended wood i used here did the following;
Soak in water-> microwave 30 seconds-> install with cloth clamps-> let dry-> glue.
Adding the right glue is a big help. Medium CA lets you fix and adjust the placement of every piece. When you are done, press the spot (watch your fingers)
