Hey Kurt, the middle row seems to run downhill to the stern - is that correct?
Please consider making a Donation to SOS to support our continuing growth and developement. It is greatly appreciated !!! *** Read More - - Click Here *** https://www.paypal.me/DonateSOS |
I believe that sudden downward placement of the last two gun middle gun ports on each side at the stern is one of the mysteries involving this model. I mentioned this in post #230 earlier. Payne and Willem Van de Welde both show those two gun ports on the end seemingly a meter or two below where you think the gun deck would be if you are following the sheer lines (planks and side galleries) of the vessel. However, we know that HMS Sovereign of the Seas was required to have three continuous, uninterrupted flush gun decks below the castles. There is a long discussion on the MSW forum about this. Frank Fox, an expert in 17th century vessels, said that the gun port do not follow the sheer lines of the hull, they follow the overall hull shape, the curvature of which is much flatter than the sheer lines. So, even though the planks run along this deep curve, the hull does not. When you see the lines of guns and the slant of the planks and side galleries together, the gun ports don't line up elegantly. The line of ports seems almost flat, even though there is some curve. I believe that artists drawing the lines of ports have to be regarded with caution regarding gun port placement. Behold how those brazen lines of guns dare cross the lines of the wales!Hey Kurt, the middle row seems to run downhill to the stern - is that correct?
I have been following along with your build so I know there are questions about gun ports that drop below the 'known' deck position. I think my comment finds it's origin in this: wouldn't the decks be parallel with one another (wouldn't the headroom be the same at both ends of the ship)? Perhaps it's parallax caused by camera position or from the curvature of the hull - but to my eye the vertical space between the upper row of gun ports and the middle row of gun ports increases as you move from fore to aft. If this is your intent then just ignore me - you know far more about your ship than I do (EPIC UNDERSTATEMENT) - but I had to ask. Patching and re-cutting gun ports later would not be fun! The orthodontist in me sees 'lines' and 'symmetry' and something just looks off.I believe that sudden downward placement of the last two gun middle gun ports on each side at the stern is one of the mysteries involving this model. I mentioned this in post #230 earlier. Payne and Willem Van de Welde both show those two gun ports on the end seemingly a meter or two below where you think the gun deck would be if you are following the sheer lines (planks and side galleries) of the vessel. However, we know that HMS Sovereign of the Seas was required to have three continuous, uninterrupted flush gun decks below the castles. There is a long discussion on the MSW forum about this. Frank Fox, an expert in 17th century vessels, said that the gun port do not follow the sheer lines of the hull, they follow the overall hull shape, the curvature of which is much flatter than the sheer lines. So, even though the planks run along this deep curve, the hull does not. When you see the lines of guns and the slant of the planks and side galleries together, the gun ports don't line up elegantly. The line of ports seems almost flat, even though there is some curve. I believe that artists drawing the lines of ports have to be regarded with caution regarding gun port placement. I would not trust their accuracy in this particular feature, any more than I would trust the sheer curve of the banana shaped ships with ridiculously high stern castles in the old paintings. You have to be critical when taking elements from art and applying them to a realistic model. Some features you trust, others you don't. Also, you can't use the design of Wasa for clues in features of English ship building, although it is tempting because the Wasa survived and we have it as a living example of an early 17th century ship. The Wasa was mostly Dutch inspired in construction, but the English have their own way of building ships... because they're English.
So what do I do with those confusing gun ports? I do not think they should "run downhill" as you approach the stern. Logic tells me the best thing to do is position the deck for these guns as an extrapolation of the middle gun deck, and adjust the side galleries such that they are where they appear to be in the paintings/woodcuts relative to the guns. The gun decks as viewed from the side should line up with the stern chaser gun placement just just. A modeler on MSW already figured that out and came up with a computer generated model using Blender 3-D that shows this. The proportions and shape of my model may look a little different than the artists' conceptions, but it will probably be a more realistic representation of a working ship.
Decks parallel? Not necessarily in a 17th century ship, ESPECIALLY in the stern castle! Look at the 1636 version of the ship below. The decks diverge slightly as you go aft. This ship was rebuild four times, 1650, 1651, 1659-1660, 1685. Major changes were made. It's very hard for me to build the 1636 version because most artists made depictions after the 1659-1660 rebuild, sometimes with a mix of features which were part of the original build but were later removed or replaced! Talk about confusing sources...I have been following along with your build so I know there are questions about gun ports that drop below the 'known' deck position. I think my comment finds it's origin in this: wouldn't the decks be parallel with one another (wouldn't the headroom be the same at both ends of the ship)? Perhaps it's parallax caused by camera position or from the curvature of the hull - but to my eye the vertical space between the upper row of gun ports and the middle row of gun ports increases as you move from fore to aft. If this is your intent then just ignore me - you know far more about your ship than I do (EPIC UNDERSTATEMENT) - but I had to ask. Patching and re-cutting gun ports later would not be fun! The orthodontist in me sees 'lines' and 'symmetry' and something just looks off.
What can I say, John? I'm a glutton for information when I work on a project. I like to gather as much as I can before making the next step because it's hard to get a model ship accurate, or many times even half right. It's part of the work, and you change your mind when new information is found. How many model makers were disappointed when they learned their blue models of Wasa were supposed to red instead? We all try to get he best information we can, or we can just skip the research and make it easier by building models of ships that never existed like the Black Pearl or San Felipe.Kurt,
The level of deep research that you rise to with all your projects is very impressive, especially with this one. Big cheers learning so much as well.
Cheers,
In a lot of 17th century ships the deck at the aft two gun ports is dropped or is showing a knick. Two reasons for this are 1 the rudder tiller is entering the ship so more room is needed for the tiller and the rudder boom (Kolderstok in Dutch).I have been following along with your build so I know there are questions about gun ports that drop below the 'known' deck position. I think my comment finds it's origin in this: wouldn't the decks be parallel with one another (wouldn't the headroom be the same at both ends of the ship)? Perhaps it's parallax caused by camera position or from the curvature of the hull - but to my eye the vertical space between the upper row of gun ports and the middle row of gun ports increases as you move from fore to aft. If this is your intent then just ignore me - you know far more about your ship than I do (EPIC UNDERSTATEMENT) - but I had to ask. Patching and re-cutting gun ports later would not be fun! The orthodontist in me sees 'lines' and 'symmetry' and something just looks off.
So, the question is then, does the deck change angle near the stern end, flattening out to position the last two sets of guns to be a bit lower, in order to make room for the rudder tiller and whipstaff and still allowing the deck to be "flush"? Dutch and English ship construction is different, so it's hard to make a conclusion here.In a lot of 17th century ships the deck at the aft two gun ports is dropped or is showing a knick. Two reasons for this are 1 the rudder tiller is entering the ship so more room is needed for the tiller and the rudder boom (Kolderstok in Dutch).
But the second reason which is more important is that the gun cariages for the stern chase ports were taken from the gun ports in the brought side. These were turned and pushed to the stern. If you would do this at a deck which is rising to the stern this would be a difficult task. A flat deck is therefore necessary. During the end of the 17th century the decks became more flat and the deck drop, knick was cancelled.
I've known of her work for a few years. I downloaded ALL her pictures one HMS Sovereign of the Seas, back when I was starting to build La Couronne, because my goal was to build SotS when I got into building these models. Did you see the chess board she made for the gallery?Kurt,
I was going through images of Doris' SotS - you must certainly know of her - Not arguably !, but THE best work in the world - anyway here is a link to the 1000s of images from her Sovereign - (at the bottom of each page it leads to the next page and so on.....
Members, if you DON'T know about her work - caution you will spend hours marveling at what seems impossible in this hobby to actually create. BTW every gold gilded piece was also created by hand. Her other ships are just as shockingly amazing - AND when she also creates the interiors - it's even more astonishing.
PS: I now need to rethink the beakshead for my current build YIKES lol -
Yours is coming along very nicely - the hull gun openings are indeed a bit odd on this one, aren't they?
Cheers,
Agree with you here, there are contradictionary contemporary sources so we will never know for sure.So, the question is then, does the deck change angle near the stern end, flattening out to position the last two sets of guns to be a bit lower, in order to make room for the rudder tiller and whipstaff and still allowing the deck to be "flush"? Dutch and English ship construction is different, so it's hard to make a conclusion here.
Now its getting exciting. Entering uncharted waters!After mowing the lawn, I had a few hours left to start planning the construction of the lower gun deck. First, some of the cannon ports were adjusted in position to make for sense from a structural support sense (avoid ports overlapping each other vertically where possible). The entry port on the port side was also shifted aft so the position closer resembles the Payne and Willem van de Velde illustrations. I'm convinced that model kit makers tend to design the positions of the frames to create the hull shape first, and let the gun ports fall wherever they don't intersect the frames, making the ports occasionally line end up where they shouldn't be.
Strips of basswood were shaped to make lower gun deck supports that have camber. They are shown near their final positions and are not glued down. Plotting the locations for hatches, capstans, and other deck openings like companionways will be done first, and each opening will be framed in basswood before the deck is laid down. Deck supports will be shifted to accommodate the deck openings. The deck will be thin strips of Tanganyika wood, the same that is typically used on many model decks, but they will have to be attached to a thin veneer in sections and laid side by side on the cambered deck support and hatch and companionway frames.
Yup. From here on out it's mostly scratch building.Now its getting exciting. Entering uncharted waters!
+1. Good tools are necessary for good scratch building, although you can do a LOT with a saw, some files, and a sanding block.Scratch building does indeed have it's + side, adding a nice building challenge. That said - this is where tools become SO important in this hobby.
