Thanks, Adi. Every one of us here is a master, a master of his\her model. You are the master of your Courier!Hallo Jim, Absolutely stunning, just looks clean and beautiful done. The master at work. And now for a cold beer.![]()
Thank you, Mon Amie! I must credit the @Trident Model for scoring those deck clamps and engineering the holders' jigs. It does make the job much easier compared to if you need to bend (both directions) and find propper position.Beautiful work, Jim! You certainly nailed those pesky deck clamps. Kudos!
Looks fantastic! Great job!Greetings folks! During the past weeks, I have some time to work on the Alert's hull, so without further ado, would love to share the progress with you, my dear readers. But first, my great appreciation to all of you for keeping the interest and being alert to my Alert log.
Well, if you recall from the last post we have finished installing the Breast Hooks and Deck clamps. The next step, Triden's manual suggesting to work and install the Lower beams (Page 26-27). Installing Lower beams assumed to install the Spirit room, Shot locker\Pump well, Magazine access lobby, and Lightroom. Further steps in the manual suggested installing upper deck beams ledges, lodging\hanging knees carlings, and other deck forming parts but...wait, don't we have to shape\sand the external hull? How much dust will the internal structure accumulate after sanding? How easy it will be to remove the dust out thereafter? All those questions\answers lead me to think about temporarily removing the hull from the berth.
So...today's post I will dedicate to releasing the hull from the berth for further shaping. If you would like to follow this path let's begin.
*** Please understand this is not the recommended path from the kit's manual, it is based on my own decision, observations we discussed above, and another Alert build of my friend @Maarten.
It is worth stepping back to the very beginning when we assembled the birth. It seems, and it is actually true, that berth assembly is a very basic and simple process. I recall myself rushing to start the berth assembly and honestly didn't even realize the pitfalls I might meet soon. Let's discuss the image on page 9 instruction manual, specifically Parts CL15.
Here we can see that all the parts are labeled with the text 'Fix with glue', all except CL15 parts. The importance of not gluing is so crucial, so... I guess for the shipwrights like myself, the image should depict the message 'Do not fix with glue'!
NOT gluing the parts CL15, will make a breeze removing the hull from the berth. Because I glued the parts I presented the challenge to unglue. I use alcohol, acetone, hot water but to no avail. The Elmers Max glue proved to be a great\strong wood glue as being advertised.I end up using the very fresh\sharp scalpel blade #11 and cut along the edges. I cannot say I succeeded without the damage, but parts were loosened enough to proceed.
Once both parts CL15 loosened, I removed all tubs holding the upper berth to the jig, and begin lifting the hull from the bow side, and...bingo, it simply slides out. YAY!!!!
Well, She is kinda free now! I wait for this moment for about half-year, just to see how the frames look outside, Again, I must credit @Trident Model for the design of the frame construction. They look pretty even and made a smooth transition from the bow to the stern. Take a look at the below photos.
The stern section
The bow section
This is the berth part after surgery performed prior to being released from the hull. Don't repeat my mistake, DO NOT glue part CL15
the CL15 parts after removing
I found another useful way if you put the hull upside down to the berth. This way you can perform light sanding and observations
Well...with the last photo, we have reached the end of this post. The next step is the dustiest work - shaping the hull. Likely, it didn't require much wood to remove. See you soon...and thank you.
内板張り 素晴らしいです。...and we continue, We will install the Breast hooks. Again, take a look at the drawings from the AOTS book. They are number 7 in the below image. All Breast hooks bolted to Apron (or false post).
View attachment 239466 View attachment 239467 View attachment 239468
In the kit, those parts identified as BL25, BL26, and BL27 (for the bow section), and BL28 for the stern section. You will need to pay close attention while fitting them. They will require a special angle and as the result a special shape to fit only on your hull. If you want a perfect fit, you will need a great number of fit-and-shape excessive. While shaping the first Breast hook, I accidentally break one. No biggie, I made a new one from scratch. On the top, the broken one.
View attachment 239469 View attachment 239470
Below is the first one installed and bolted.
The second Breast hook bolted as well. Use the notch as the guide.
The last one for the bow section is installed. While it doesn't have the steps as the first two, its shape is very complex. You have to control the joint part (notch), left and right side as well as the angle.
Below is the bow section after installing all three Breast hooks.
The last one is the Stern Breats hook.
View attachment 239477 View attachment 239478
Here is the notch for the hook
...and it is installed
The final photo of the ship after installing all Breast hooks.
That's all for now, I will be happy to see you in the next update where we will discuss the lower hull structure. See you soon and thank you!
素晴らしいです。 次回の投稿が楽しみです。Greetings folks! During the past weeks, I have some time to work on the Alert's hull, so without further ado, would love to share the progress with you, my dear readers. But first, my great appreciation to all of you for keeping the interest and being alert to my Alert log.
Because NOT gluing the parts CL15, will make a breeze removing the hull from the berth. Because I glued the parts I presented the challenge to unglue. I use alcohol, acetone, hot water but to no avail. The Elmers Max glue proved to be a great\strong wood glue as being advertised.I end up using the very fresh\sharp scalpel blade #11 and cut along the edges. I cannot say I succeeded without the damage, but parts were loosened enough to proceed.
The stern section
The bow section
Thank you, my friend! I am trying...Looks fantastic! Great job!
Many thanks, Mon Amie! I couldn't be happier to know that the information in the log might be helpful. Yes, despite some minor flaws, the kit is very well designed in mind for a first POF kit.Hallo Jim my friend, very well explained, excellently presented. Very nice frame design, just a super built model, really enjoys watching your work.
Thank you, my dear friend! Yes, my Admiral is not too happy with my first sanding session, contrary, I am not super happy with my 'outside designation by her. It is about +30C those few days. The good thing, it is really not much to sand, just to make everything even...HAPPY SANDING - and enjoy it making the final touch of the hull
Looking very good my friend
Thank you for your comments and welcome to the build log! I hope you will find it informative and usefulEnglish translation
Wonderful. I'm looking forward to the next post.
Many thanks! Yes, there will be dust, but as you mentioned and I visually observed - not too much. I will need just to even the frames to form a nice smooth line. That's the idea ...As Uwe said Happy sanding!! Although looking at photos you done great job installing ribs etc so shouldn't need that much great job
Thank you, Jan! As this is my first POF model, I am learning myself!Your hull looks fantastic. Very nice work.
Hallo, Fritz. I am grateful for your comments and happy to know that you find the explanation details useful....very good explanation - useful especially for coming builders like me (and a "little hint" to Trident). The model looks great, congratulations!
Hi Jim,Greetings folks! During the past weeks, I have some time to work on the Alert's hull, so without further ado, would love to share the progress with you, my dear readers. But first, my great appreciation to all of you for keeping the interest and being alert to my Alert log.
The stern section
The bow section
Amen! Echt heel erg bedankt, Peter!Hi Jim,
A very nice transition of the frame. And during the sanding you are gone love the shape more and more. Let her rest on your knees and let your hands flow over here curves!
Hmmm...mmm....I hope we are thinking of the same 'her'!A very nice transition of the frame. And during the sanding you are gone love the shape more and more. Let her rest on your knees and let your hands flow over here curves!
Oh Yes, Jim. In your build (and after the previous discussions) this ship is 'female’ and she’s the ‘her’.Hmmm...mmm....I hope we are thinking of the same 'her'!In any case, let it be!!!
