Very nice mill work going from your own milled lumber to the finished turned and detailed mast. Well done. Rich ((PT-2)Very good work on the beams and hatch carlings. Not easy to make all of them with the correct curve
Well done !!!
Dear ManatasStory of making masts:
View attachment 249026View attachment 249028View attachment 249029View attachment 249030View attachment 249031View attachment 249032View attachment 249033View attachment 249034View attachment 249035View attachment 249036View attachment 249037
now looking for best ways to make mast wedges..
You know, I would like to see the sheaves cut into the lower part of masts for raising and lowering them at sea. One false move and you have a very heavy arrow dropping and piercing the hull, possibly clear through and then they may have to cut away the ropes dragging it along. Yours are well made and placed. Rich (PT-2)Story of making masts:
Very nice small work for very realistic pump handles. What type of pump are these associated with?Before deck planking it was necessary to make bilge pumps, so this thread about making them. View attachment 258782View attachment 258783View attachment 258784View attachment 258785View attachment 258786View attachment 258788View attachment 258789View attachment 258790
Hello, Rich and Manatas. This particular pump is called Bilge or Elmtree pump because the tube was made from the Elm tree.Thanks Rich for a good word. I don't know much about types of pumps, just made them according plans and a little bit of my imagination.
Thanks Jimsky, very helpful information and good direction to obtain this bookHello, Rich and Manatas. This particular pump is called Bilge or Elm pumps because the tube was made from the Elm tree.
Check out this very interesting document, it is a great read to expand the knowledge, IMHO. BTW, the image you provided, taken from this book.
You have very good thesis here. I recognize some of the top signers as the leading nautical and underwater archealogical researchers and academicians of many decades. You have excellent drawings to build and understand the pump. Rich (PT-2)Hello, Rich and Manatas. This particular pump is called Bilge or Elm pumps because the tube was made from the Elm tree.
Very nice work. 1:36 is a nice large scale for such detailing. It will be quite a ship. Rich (PT-2)Before deck planking it was necessary to make bilge pumps, so this thread about making them. View attachment 258782View attachment 258783View attachment 258784View attachment 258785View attachment 258786View attachment 258788View attachment 258789View attachment 258790
Thanks Thomas for showing me where I can find more photos than in monographie book, I wonder how they didnt mentioned in the book this kind of info. But, in this case, I see that everybody and even F. Fissore making deck flat, but as I understand by plan - "Stronger" plank are set in the cut out in the deck beam, then middel panks are at the same level on top, but side planks are thinner and makes different height, just cant undestand how they should end and merge with waterway... Or my plans understanding is bad and I need to make every planks flat?Hi Manatas!
Stronger (thicker) deck planks are set into the cutouts in the deck beams (similar to the carlings). They are not protrude from the top of the deck, simply because of the risk of tripping.
On the "Ancre site" you can find numerous construction photos of the Del Rosario.
In the fotos, the top of the deck is always flat. Except for the bend through the deck beams.
Best regards
Thomas
Hallo Thomas,Example from wood scraps:
1: Deck beams. Above it two thin and one thicker deck plank. The deck is flat on top.
This is achieved by cutting out the thicker deck plank at the bottom between the deck beams. Then it also looks like the cross-section drawing of the construction plan.
Best regards
Thomas
I can understand your thoughts completely, but I have no other idea of how it could be done differently.Yes Uwek, I thought the same, but I was so unsure that didn't make myself to do that and was afraid is that possible that it will be small "corner" between deck plank and waterway where floor heights will be different in a very beginning of plank.
