N. S. Del Rosario / 1759 Felucca/ 1:36 building log
Very good work on the beams and hatch carlings. Not easy to make all of them with the correct curve
Well done !!!
Well done !!!
Very nice mill work going from your own milled lumber to the finished turned and detailed mast. Well done. Rich ((PT-2)
Dear Manatas
Just today I got to know your amazing blog for building this beautiful model. I must say that I was very impressed by your highest quality and most accurate work. I will continue to follow with great curiosity Thumbsup :) Thumbsup
You know, I would like to see the sheaves cut into the lower part of masts for raising and lowering them at sea. One false move and you have a very heavy arrow dropping and piercing the hull, possibly clear through and then they may have to cut away the ropes dragging it along. Yours are well made and placed. Rich (PT-2)
Very nice small work for very realistic pump handles. What type of pump are these associated with?
Rich (PT-2)
Thanks Rich for a good word. I don't know much about types of pumps, just made them according plans and a little bit of my imagination. To understand how it works I used this draft yP5kp.png
Hello, Rich and Manatas. This particular pump is called Bilge or Elmtree pump because the tube was made from the Elm tree.
Check out this very interesting document, it is a great read to expand the knowledge, IMHO. BTW, the image you provided, taken from this book. ;)
Hello, Rich and Manatas. This particular pump is called Bilge or Elm pumps because the tube was made from the Elm tree.
Thanks Jimsky, very helpful information and good direction to obtain this book
You have very good thesis here. I recognize some of the top signers as the leading nautical and underwater archealogical researchers and academicians of many decades. You have excellent drawings to build and understand the pump. Rich (PT-2)
Need help! Best would be somehow visually to explain for me how should I do thickness crossing on waterways when thickness of deck planks are different? As I can find in other sources and monograph examples everybody is doing planks at the same thickness, even in photos on original monograph I cant see difference of planks thickness. But plans and measurement information tells that thickness must be different. I just dont cnow how should be done bevieling on waterways in those places. Thanks in advance. IMG_20211024_222837.jpgIMG_20211024_222801.jpg
Hi Manatas!
Stronger (thicker) deck planks are like the binding-strakes on larger ships. They give the ship greater rigidity. For simplicity, they are executed on many models as normal deck planks. They are not protrude from the top of the deck, simply because of the risk of tripping.
Binding-strake (8) in the book "The 74 gun ship", Volume 1, page 110.
On the "Ancre site" you can find numerous construction photos of the Del Rosario.
In the fotos, the top of the deck is always flat. Except for the bend through the deck beams.
Best regards
Thomas
Hi Manatas!
Stronger (thicker) deck planks are set into the cutouts in the deck beams (similar to the carlings). They are not protrude from the top of the deck, simply because of the risk of tripping.
Best regards
Thomas
Thanks Thomas for showing me where I can find more photos than in monographie book, I wonder how they didnt mentioned in the book this kind of info. But, in this case, I see that everybody and even F. Fissore making deck flat, but as I understand by plan - "Stronger" plank are set in the cut out in the deck beam, then middel panks are at the same level on top, but side planks are thinner and makes different height, just cant undestand how they should end and merge with waterway... Or my plans understanding is bad and I need to make every planks flat? IMG_20211024_222837.jpgIMG_20211024_222801.jpg
Example from wood scraps:
1: Deck beams. Above it two thin and one thicker deck plank. The deck is flat on top.
This is achieved by cutting out the thicker deck plank at the bottom between the deck beams. Then it also looks like the cross-section drawing of the construction plan.
Best regards
Thomas
Hallo Thomas,
many thanks for the work with the example, but unfortunately on the Rosario the deck was not build like on a french warship, she had really a step on the top of the deck
So I think that there will be no other way than to adjust the difference in height of the 0,5mm over a certain length of the waterway along the lower plank (marked with red)
Yes Uwek, I thought the same, but I was so unsure that didn't make myself to do that and was afraid is that possible that it will be small "corner" between deck plank and waterway where floor heights will be different in a very beginning of plank.
I can understand your thoughts completely, but I have no other idea of how it could be done differently.
On the photos of the build included in the ancre booklet this detail is not really visible.......
