Im envious of the english instructions!The instructions are a vast improvement from previous kits. The step by step assembly instructions are in English.
Looking forward to this Brian, are you planning the "big cut" on this hull also?
This is a NMM modelThis photo is from Tom at CAF model. This is what I would like to achieve with a split hull showing the internals.
.View attachment 249134
the model on the image is from the National Maritime Museum GreenwichSay Waaaaaaaat........is a NMM model
I know that Lol@zoly99sask If I read correctly, Bryian did not say it is a model that Tom built, merely a picture that Tom supplied.
I like the Graphite and Glue concept, is it better than the Black Dyed Paper process?Assembled the Cherry wood keel. The notches on the keel are for accurate alignment on the building board, and will be removed later.
I am mixing white carpenters wood glue with graphite from a pencil to show up the black calking between the timber.
.View attachment 249129
Hi Paul,I like the Graphite and Glue concept, is it better than the Black Dyed Paper process?
The photos and drawings on the NMM-web-page can be used if they are used for educational purposes and you have to mention that they are taken from the NMM-pageYes the photo above is a museum model, I believe he has purchased the rights for the images and plans.
