- Aug 8, 2019
Yes the second from the left is wrong. But the other side got one wrong too. I noticed this to late. And to much work to start over.As if the guys were wrapped around the sufers in different directions
Stefan, not a lot of work. But of course it's up to you to decide. You just need to bandage the lanyards and unfold the ufers in the wrong places.Yes the second from the left is wrong. But the other side got one wrong too. I noticed this to late. And to much work to start over.
Not the work. But all is already glued in place. I think I do more harm then good. I can live with it.Stefan, not a lot of work. But of course it's up to you to decide. You just need to bandage the lanyards and unfold the ufers in the wrong places.
yeah I think your right, just find the middle way. Going from parallel on the futtock to the waterline to parallel to the channel makes a messy look.I would go still with ratlines parallel to waterline... with slight angle![]()
Thanks Kirill. And I know were it went wrong with the block stropping. Every piece got another diameter and I used the rope that was supposed to use on the main tackle for the mizzen. Because in first I was start on that mast. Stupid but I learned and next time it wil be perfect. I made an excell file were all the diameters of all the ropes are auto calculated. I posted it a while ago.Stephan Good day!
Nice!))
Good progress!
