True.Great work all those guns are going to keep you busy.
Looks nice indeedI’ve built my first gun carriage for the upper guns with long tails. View attachment 250974
I think the gun may be too heavy. View attachment 250975
But maybe they want to kill some whales!
Anyone know what these guns/carriages are called and how they are rigged?
I haven’t looked at Big Mike’s log. I have poured over yours, paulb’s, and Mr.Deep’s and discovered a wealth of information. Thanks for keeping in touch. I appreciate it.Looks nice indeed
One option you may want to consider is bending the rear part of the gun (see log from Bigmike). I have not done that but considering to make this change.
I have used small brass strips to hold the guns on the carriage and have glued the carriage on the deck.
Hey, Vic. I think I need to get this breadboard. I think it is magical...you asking for daily bread and get the vises! Wow! Is it daily delivered? What other tools did it offer? May I ask for a metal lathe? I mean I already have vises, don't need them anymore.New toys! I have vices…I mean vises.
I think I'll just live for it!I agree. No type of construction can ever be sturdy enough. Beautiful tools Vic! That Proxxon number is to die for!
Hi VicSome of the gun support boxes didn’t feel that solidly placed. I reinforced them by gluing steel wire into them through the plywood gun port strips. Then I cut the wires off flush. I don’t want the boxes to fall off after I seal off the hull with planks. View attachment 251658
. I see it. It seems weird to cut all the supports off. Do you overlay the inside with second planking as well?I did plank the upper part of the inside hull using P1 (same as the rest of the hull); I then using planed the upper part of the inside using P3.. I see it. It seems weird to cut all the supports off. Do you overlay the inside with second planking as well?
Yes. That’s what I was thinking of doing. Did you glue the hull planks to the supports before cutting the bulkhead supports off? How did that go?I did plank the upper part of the inside hull using P1 (same as the rest of the hull); I then using planed the upper part of the inside using P3.
It makes the inside much nicer.
Of course I only planked above the decks
Makes sense?
See below
When you did the upper inside with P1, didn't that increase the thickness too much? I'm almost to that point.I did plank the upper part of the inside hull using P1 (same as the rest of the hull); I then using planed the upper part of the inside using P3.
Makes sense?
See below
VicYes. That’s what I was thinking of doing. Did you glue the hull planks to the supports before cutting the bulkhead supports off? How did that go?
Hi IngeWhen you did the upper inside with P1, didn't that increase the thickness too much? I'm almost to that point.
