It looks like we have same opinion about these books!
What size of the blocks did You used for gun tackles?
> 2.0mm ; 2 .0mm; or < than 2 .0mm?
Are they self made?
Looks a little bit too big / slightly out of scale on the picture for this size of gun carriage....but I could easy be mistaken!
I didn't see conventional blocks smaller than 2.0 mm which could be purchased on the market...
Yes, it is a very intensive hard work, dealing with these small blocks!Dear Dfolgado,
Now I see!!!
Huge jobs to fabricate all those necessary blocks!!!
especialy in size of 1.8 mm!!!...
one time I did myself blocks for my model, including 2 mm... made 50 % of necessary q-ty and exhausted![]()
And asked one of collegue to cast all the rest from resin by my master models... thats was great relieve for me!))
Later on I found very nice and accurate blocks could be purchaised from different models shops up to 2.0 mm in size...and on the finisf of my model I used them as well...together with selfmade...
But smaller . than 2.0 mm still need to be made ourself!))
I think I will try to use 2.00 mm blocks for making 1.8 mm... I will try to use some thin cap with sand paper rolled inside , attached to the drill and 2mm blocks placed inside, and rotate it for a while thus reducing size of 2.0 mm blocks... This is idea...need to try...
Thanks for the accessories info, I will take a look at them.I saw You used conventional threads for tackles?
At least on the photo it looks like not made ropes...?
Actually, the tackles rope is a made rope composed of 3 strands of cotton 100.
The 3 strands end up with a diameter of 0,2 mm, it is the finest diameter that I can make in my rope machine.
Please take a look at this closer photo, although it is not easy to see:
It is so small, that probably it was simplest just to use plain thread, but even that it is not easy to see it, we know it’s there…
This Heirloom thread that I use is difficult to get, I can only buy it in one place in the USA, but it arrives in Portugal extremely expensive! The Gutermann 100% cotton is also a good solution, I tried it already. The problem is that I cannot get it anymore in Portugal and they only have 50wt thread. Heirloom have both 70wt and 100wt. This makes a big difference.Thanks, now is clear... when not painted,difficult to see thread structure!
I see You prepaired already almost set of the ropes!at least half of them definitely...
You managed to find fine cotton thread , no furs!!! Great!
I use Gutermann poliester... didn't find nothing suitable made from cotton...
Hi János,I am also using #100 cotton. (DMC Crochet Cotton). The finest I can make of it (3 strands) comes in about 2.7 mm, definitely closer to 0.3mm than to 0.2mm. How come you can achieve 0.2mm (which I would like to make too)? Is #100 not equal to #100?
János
Good day,This Heirloom thread that I use is difficult to get, I can only buy it in one place in the USA, but it arrives in Portugal extremely expensive! The Gutermann 100% cotton is also a good solution, I tried it already. The problem is that I cannot get it anymore in Portugal and they only have 50wt thread. Heirloom have both 70wt and 100wt. This makes a big difference.
I thought ropes made with poliester thread become very elastic, this is not the case?
Poliester thread is easier to get…
I see that is easier to get Gutermann in Russia than here in Europe…Good day,
Gutermann poliester ,which I used ...I can't say it has some kind of elastic...
All my ropes painted entirely before use...after painting thread became such as soft copper wire... very handy for use...
Before I used Guterman thread seria TeraView attachment 252164 and recently chosed one more type which is more handy for ropes making...
Seria Skala View attachment 252165 this is like very thin mono thread and in combination of several strands as You explained above, You could get any sizes of the rope You need.
I bought them in 3 sizes, and in spoon of 5000 mtrs, which I think will be life time stock for me))
On the pictures You could see item number No of each thread and name...
In left corner adress of supplier where I ordered them www.legus39.ru
But I think it could be ordered from any other supplier in Europe as well...
