Belle Poule 1780 1:72 - Sail and Sail Model by zoly99sask
zoly99sask
Administrator
Administrator
Forum Moderator
Saskatoon,Canada
Hello folks, here is my new build log for this beautiful ship and kit, I skip the unboxing as Jim did a beautiful job on it along with a kit review.
So I kicked off assembling the jig, the parts not required any sanding, they fit together as they are perfectly, using wood glue, clamps, and some weights
6.jpg​
IMG_9334.JPGIMG_9335.JPGIMG_9336.jpgIMG_9337.JPGIMG_9339.JPGIMG_9340.JPGIMG_9341.JPGIMG_9342.JPGIMG_9343.JPG
Hello, Mon Amie! This is the one I will definitely watch as I will start my build log pretty soon! It does look, it is a straightforward process, and you don't have any trouble assembling the initial jig. For those who might wonder, there is a total of three jigs. First for the upper hull, second for the lower hull, and the third one for the entire ship assembly.
Good luck, and Sail ON!
So that sounds like three logs and a fourth for the ship and all without a log jamb in the flow I suppose???
Fun every step of the way with three warm-up builds and one longer . . . much longer one. This will be interesting to follow. Rich (PT-2)
Hello folks
Assembling the upper hull frames, there is a right side and a left side, both sides have frames that are made up of 2 parts that need to be glued together, this glued frame parts on each side of them shows/have laser engrave to show where needs to be beveled.
7.jpg8.jpg65154973383__A3FDB0C9-4C9C-43C2-B386-64733F21AE03.jpgIMG_9414.JPGIMG_9416.JPGIMG_9417.JPGIMG_9418.JPGIMG_9421.JPGIMG_9422.JPGIMG_9423.JPGIMG_9424.JPGIMG_9425.JPGRenderedImage.jpg
Hello folks
View attachment 253208View attachment 253209View attachment 253210View attachment 253211View attachment 253212View attachment 253213View attachment 253214View attachment 253215View attachment 253216View attachment 253217View attachment 253218View attachment 253219View attachment 253220
Those laser cut sheets of frames look like a parade of goose-stepping troops shoulder to shoulder. Your work is definitely getting them in place very well done. This is going to be interesting and I hope enjoyable for you. Rich (PT-2)
It is already enjoyable build,interesting design
