Anxious to know if the bobbin spooler on your machine works correctly. Mine runs too fast(dangerous) and there doesn't seem to be a way to slow it down. The rest of the machine worked great. What I am calling the bobbin spooler is the little device on the right side of the unit that is used to thread the little bobbins.
Hello. yes it is.G'day Jack, is your rope walk the same make as mine, I haven't got to the electrical part yet, so hopefully all will be well,
Best regards John,
Your walk is a build in itself!!! With the finish it looks great . . . hope that it works as you anticipate. Rich (PT-2)View attachment 264773
attaching the veneer, the piece at the back is just sitting there,
the front attached, I was really surprised at how easy the veneer went on, it fit like a glove,
So thats all the veneer attached,
overhead view,
no veneer was included for the spool take ups or the motor mounts and also the tall piece at the back, so when i varnished the veneered parts I also gave the other pieces a coat of the varnish, see next pic,
everything varnished, I will probably give the motor mounts and spool holders another coat,
Next up will be the mechanics and the electricals, keeping my fingers crossed,
Thank you for looking in,
best regards John,
