Thanks Jack, I will give that a go tomorrow,No it's infrared. what i did to test is i simply put a flathead screwdriver in front of one of the sensors.
Best regards John,
no worriesThanks Jack, I will give that a go tomorrow,
Best regards John,
G'day Kurt, yes once it's up and running, probably be a little while yet, but I will definitely follow up,Will we get to see samples of rope made with your new machine, after you get some practice?
you should ask the supplierHi, could you please tell us about the shipping and duties for CANADA ?
Even for the duties ?you should ask the supplier
That's interesting that you had troubles with Domanoff. I have his serving machine with the motor, and the motor wire broke off. It wasn't soldered on properly. I am going to try to get another motor from the guy. I'll let you know how I made out.Yes, but I was unable to cinnect to his site. Win 11 problem? And I had bad experiences with his erving machine too.
Thanks for the french part.
DOmanoff said he will send me another motor. Great!That's interesting that you had troubles with Domanoff. I have his serving machine with the motor, and the motor wire broke off. It wasn't soldered on properly. I am going to try to get another motor from the guy. I'll let you know how I made out.
well doneView attachment 266412
Just fixing the corner protectors in place, gave me a chance to try out my new cordless mini drill,
a better pic, the chuck I added myself, the drill is small and light and drills in wood no worries,
The corner protectors in place,
and a view with the cooling fins attached, that's all the electrics done now, just wanted to say to Jack, everything works fine except for the bobbin reel on the right hand side, when I turn it on it goes like crazy and there doesn't seem as if there is any way to control it, and also it will not turn off, I might do what you mentioned and see if I can get a on off variable speed controller, apart from that the take up bobbin and the motor for the planetary discs work just great, I have put it aside for now and will try and get the variable speed controller, then it will be assembling the planetary discs, thanks everyone for looking in and all the help and comments,
best regards john,
Thank you,well done![]()
