Steam powered wooden Drifter trawler, Formidable LT100, 1/20 scale by neptune
G'day Steve, you made a fantastic rudder assembly, over 50 percent of my rudder build is credited to you, I was just going to build a simplified version, I downloaded and studied all your photos and decided to give it a go, now I am looking at cutting out the end supports for the inner rudder post to finish the job properly like you did, thank you for posting all the detailed photos,
Best regards John,
G'day John,
In a sense what I meant was your slightly simplified version shows your skill at representing the real thing without putting a silly amount of time into this assembly like I did, neither one is wrong. Your version shows me a skill I don't have, that is what not to show and what to show.
This is something I hope to learn with more experience.
Keep up the great work, we can all learn something from each other and I am truly very happy you found inspiration from my build.
Cheers,
Stephen.
Space was getting a little bit on the tight side so I cut a slot up the inner side of the stern post for soldering the
bracket to, and I decided to solder the lower rudder post toe bracket to the outer side of the rudder post,
Closer view,
I was a little bit frightened to solder this close to the wooden boards of the rudder, but was lucky and only managed
to singe the very bottom corner, this is the starboard side,
and the same on the port side,
test fitting to make sure all turns OK,
next job was to fill in the under keel area where i was originally going to have the rudder post support fitted,
here you can see the area made good and showing the notch that the stern post will fit into,
To fit the assembly in place I rotated the rudder 90 degrees and slid it down into the tube,
then rotated the stern post back to the fore and aft position,
then the leg of the tee stern post fits just nicely into the slot and once I have drilled and fixed miniature bolts in place
all will be secure, I still have to cut and attach the sand iron that runs down from the top of the bow and all along the
keel, I'm trying to work out the safest way to cut the brass strip that I have,
So its time to start the painting of the hull, these are three pics of the first coat of primer, she will need a couple
of good rub downs with filling and sanding in between, just got to be careful I don't want to get too good a finish
on her, she was a work boat,
Thank you for dropping in and viewing my build,
best regards john,
Closer view,
Impressive. I would have burned the whole thing to ashes.
Closer view,
First of all I want to commend you for the impressive work you do! Question: What material do you use to salt the brass pieces?
Beautiful work John. ThumbsupThumbsup
Cheers,
Stephen.
best regards john,
Hi John,
Looking forward to seeing her painted.
Cheers,
Stephen.
a couple of pics of the rudder bracket bolted to the keel,
and with the bolts cut back,
after a coat of black paint on the port side and a good rub down,
and the same on the starboard side, the the large white area in the middle is where the Fibre Glass matting over
laid each other and it took a bit more sanding to flatten it,
Thank you Steve, I'm pleased with her, but I was sorry to have to cover the planking, I have to check the book to see if she had a red anti fouling coat, I think she was just black tarred,
Best regards John,
Hi John,
Pretty sure it is red oxide, at least that is what I will be painting mine when I get that far.
Cheers,
Stephen.
Hi John. I really had to play catch-up now, You have made excellent progress on your build. The rudder construction and your soldering are both top notch. The painted hull looks good - industrial and workman-like keeping in character with the boat. But I do agree with Stephen - a red oxide finish will just break the black somewhat.
Thank you Heinrich, for the nice comments and yes I think also that red oxide would finish her off nicely,
best regards John,
