Thanks JohanCongratulations on reaching this major milestone!
Enjoy the next leg of your journey.
Thanks PeterHi Mark. Your BN looks great! And in the daylight, the pictures shows all the natural colors and painting well.
I am shure you will find your way through the rigging proces and building up the masts.
Hi DomCee, thanks for taking the time and trouble to comment and post all that valuable information, much appreciated. I checked my bookmarks of Bluenose II builds (I have a few) and realised that I had referred quite regularly to your build log during the course of the past few months. You have done a superb job with your model and the paintwork is particularly impressive, not to mention the bespoke modifications which I could only dream of. Your initial log petered out sometime in October '21 and I am glad to see that it lives on again in a second instalment. I look forward to the photos and picking up all the tips I canHi again,
Some very stormy weather in the UK today, so I sat in my work room and have just put the finishing touches to the ship. I will take some pictures of the completed model and post them on the forum in a day or two. Having gone through the rigging process (hell) and adding all of the details that I could find, I thought to pass on some reference notes (in MS pdf printer format, so I hope they are readable) from my build which includes some snips of the rigging that I found really useful to see where everything goes! I hope you find it useful, good luck with the rigging!
Hello Domcee, Nomad,Hi. I somewhat agree with Mastinis's comments about the rigging, it is the most difficult part of the build on a model sail ship. Simplifying the rigging does make life a lot easier and it doesn't really degrade the look of the model. I decided to go all-in (OCD?, definitely!), but it did take me quite some time researching and drawing up a rigging plan based on pictures and references so that I could do a full rig. The down side is that I have spent the last 7 weeks going very cross-eyed rigging the model. Rigging the masts off the ship as much as possible is a good idea. Once the rigging is on the ship, you need to be so careful not to snag or cross the lines. One thing I found was that the belays behind the dead-eyes are too thick and tall and need to be trimmed down otherwise you will find that the deadeyes will push against them and will not sit correctly when you tie the shrouds. I hope you decide to make some new sails for the model, I'm certainly glad that I did. I really did not like the ones that came in the kit. For me the sails were one of the reasons I wanted to do the BN. Being so prominent they really add the "wow" factor to the model. I found making a new set not to be that difficult to do. Once I had worked out all the sizes and angles I needed for each sail it only took me 3 evenings to mark-up, cut and sew all the sails - which as things go was really quick. I found some nice cloth from my local haberdashers which worked very well (a little on the thicker side than I would have liked but perfectly OK) or, you can easily buy sail cloth from model suppliers.
I will post some pictures of my build in the next day or so and also include a little post build review.
Thanks for the warning DomCee! Maintaining the tension equilibrium makes perfect sense. I already have the construction of those little jigs on my to-do list, so I'll simply add a 'x2' to the entryPS. one last thing, I made the mistake of tying my first pair of shrouds on one side first, so when I came to tie the opposite side, the shrouds were not evenly tensioned. You need to make two sets of the jigs and tie off the opposing port and starboard pairs at the same time to avoid pulling the mast unevenly (obvious in hindsight, but at least I only had to redo one run!).
Looks great! Good job!Mainmast, foremast, and respective topmasts cut and tapered, trestletrees assembled, topmast blocks attached, mast caps adjusted to size. Time for a mast-stepping dry run
I used to put mine in a drill (wrap with masking tape to prevent damaging the end in drill), and then turn while filing or sanding. You have to stop to let it cool off, will get hot and burn your hand, as I support the end with my hand while removing material.Came out well Mark. I’m also thinking how to do my mast and booms. Gonna have to hand sand them as well (tool limited )and your method may be something I can attempt![]()
For the pitch between the deadeyes I used a very simple 2-pin jig. Very cumbersome. Next time I'll take on board the 6-pin design Domcee shared.Hi Johan and DomCee, thank you for your valuable advice. I am sure it will all come in very useful and I especially like the jig to line up the deadeyes and assemble the shrouds. It seems to me there are a few key points I can take away from your experiences, viz. the sequence in which rigging is done, to do as much of the rigging as possible off-site, that the installation of rat-lines is not a walk in the park, that the supplied sails are probably inadequate, that I will likely cross rigging wires at some point and that I will require an enormous amount of patience to get through it all
I do like the idea of furling the sails. I would have thought that it might be an easier option than committing to a full rigging of the sails and I would be interested to know, Johan, why it had such an adverse effect on your anatomy
But if nothing else I will take on board that rigging is something of a delicate operation and to give it the respect it deserves. I must still come to terms with the science behind running rigging in particular, as I am sure this alone is half the job. For now though I am still at the tapering-masts stage of the process and I will contemplate all this good advice while I tackle all these other new concepts such as trestletrees, boom rests and mast caps![]()
Or leave the beers in the fridge...It is for these types of exercises (and many more to come I am sure) that I found the use of a magnifying glass invaluable. It helps to reduce the three holes that I see close up to the single hole that actually exists in the mast block![]()
The jig is a good idea. I personally would leave the lower pin of the out of the two goups, as the two upper pins would retain the deadeye in the correct position.Ah - the rat lines! Yes they took ages, worst part of the rigging experience, I counted 328 clove hitches, each tied with tweezers whilst avoiding all the other rigging and then each locked in place with CA. I could only do a few lines at a time and then had to stop and come back to it later.
For tying the shrouds and getting all the deadeyes at the same level I have seen a few methods. I tried the pieces of wire through the holes method but I found that was very fiddly and the wires kept moving so I made a couple of jigs using some scrap wood and pieces of brass wire so that they could be pushed in from behind. I pushed the pegs into the lower dead-eye and then tied one upper dead-eye and put that on the jig. You can then place the other jig and dead-eye on the next position run the line around the mast top and bring it down to the other jig. It was then very easy to adjust the tension and seize the two lines together at the top and around the second deadeye without anything moving. I could then remove the shrouds from the jig and do the remaining pairs in exactly the same way. You can then leave the shrouds out off the way and do all the other rigging. When you lash the pairs of deadeyes together they will all pull to the same length (just make sure the lines go to the same position you tied them in!). I made the pins about 7mm long so that they could be bent a little if they did not line up with the holes in the dead-eyes
PS. I put the pictures of my model up on the forum as Part 3.
