Yes, I have a slot car collection in 1/32 scale. The detail is very impressive! So they are working models…lol. I have embellishments on most of them, as I like to add detail. They are categorized by type of race car. I have vintage F1, Trans Am, LeMans, CanAm, Endurance, etc.Dean, Are your cars slot cars? -
Yes over the years I have collected 1/24th from Danbury, and Franklin Mints. I also collect 1/18th from AutoArt and CMC. I no longer add to the car collections as tempting as some of the new releases are....
I also have many 1/400th scale airliners, to which I occasionally add (just pre- ordered a SWA 737 Max 800 in their new livery style) - an aircraft I have been in four times so far.
Jack; thanks as well - bit of an improvement from the early days lol..
If you were building the later version of the vessel, the Royal Sovereign, that wonderful coat of arms would be high on the stern. As for the guns facing the waist, those are there to prevent boarding. Not all the gun ports would necessarily have guns, since several would be empty most of the time to keep the weight down that high in the vessel. There are at most 102 (usually about 96) guns on the Sovereign at different times in her career, and 118 gun ports. These make perfect sense for this type of ship - the floating fortress. Guns that were present on the castles would be maneuvered to whichever port was necessary to aim down at the waist at boarding parties. Bear in mind, boarding a ship was more common a tactic at this time than pounding a vessel into surrendering. The ship is a floating castle in the 1630's, not so much a long range artillery platform, which would become the favored French tactic a hundred years later. I assume these guns would be loaded with grape shot, never ball during a boarding action. When aimed outboard, their contribution to the firepower of the broadside was limited due to their smaller weight and caliber. They worked more like house defense shotguns do. The visible deterrent is secondary. Later, when guns made of iron became longer in range and more powerful, anti-boarding cannon quickly disappeared, leaving only swivel guns to cover that roll. This ship is representative of the tactics of the time.Hi all,
Here are some updated images of work on the quarter deck bulkhead. A lot of “artistic” license here – Purists will be annoyed lol…
Historical images do indicate most likely four forward mounted cannons – yup, I get that. Note last 4 images FYI….
I chose to allow for two, per an early drawing intended to only illustrate proposed decorations – and those two cannons won’t be mounted either at the forecastle (when it’s time to add carriages properly rigged to all the upper decks.
The visual intentions are for the side carriages to be rotated between the two openings (forward and sides) that are very near to each other on each side (see instruction guide image??? – much too crowded) I did add the recoil ropes purposefully.
I could have, instead, just added two central cannon openings, then installed railings on each side of bulkhead, but I was determined to find a good location for the SotS crest that came from Amati bits, and I like how this sort of matches the look of the centrally mounted bell at the forecastle.
Now onto the next area – I very much appreciate your visits, likes, and such kind comments – thanks indeed.
View attachment 274602View attachment 274603View attachment 274604View attachment 274605View attachment 274606View attachment 274607View attachment 274608View attachment 274609View attachment 274610View attachment 274611View attachment 274612View attachment 274613View attachment 274614View attachment 274615
Looks great! I love Artistic License!Hi all,
Oldflyer, I have not found any illustration which shows any color on the stern of HMS Royal Sovereign other than gold. That it not to say that color was not used, only that the few paintings of the Sovereign made after the ship's rebuild of around 1680 show the ship in the distance, with less detail, and no hint of color other than gold. Note that the HMS Prince Royal of 1610 shown below , the precursor to the Sovereign, did use color for coats of arms. As for the Sovereign, King Charles I specifically ordered that no colors be used other than black and gold. Many have strayed from this fact and added color to their models of the Sovereign, such as the red stripe above the waterline, but the ship as originally built was purely black and gold. The red on the railings at the top of the bulwarks you see on later paintings was probably added after the first or second rebuild, when the ship was known as HMS Royal Sovereign. Perhaps they painted the coats of arms after the refit, but I have not seen any evidence of that yet, but then again there is a lot of info out there I have not seen.Kurt: your depth of knowledge and elocution are always so appreciated. Thanks, as always, for taking the time to respond with very sage knowledge… As you know the Sergal kit includes a large coat of arms for the stern. I intend to install and paint that as well.
After having found a painted example below (Google image no reference to this brilliant builder’s name) painting the coat of arms seems more historically accurate, I think?? Noted that the Heck painting has the entire stern in gold.
For this project the stern, galleries, balconies and such – will be from scratch; adding as much detail as I can think manage - the five lanterns will also be detail upgraded – including adding clear lenses.
I know that much of this upcoming work will be historically very inaccurate. Nonetheless – this ship, in general, is an “eye catcher” indeed – out of the box or otherwise bashed….
Paul: I was tempted to leave those old Corel Vasa lions bright plated - will revisit your suggestion. Interesting that you would make that notation – Are you suggesting that I leave the heads in gold and just add some paint to the outer edges of the mains? thanks..
Daniel: Indeed Kurt cleared that up lol..
Dean: thanks
Parenthetically I also realize that the forecastle belfry is questionable. That said not attaching the kit provided wood bits was, for me, a no brainer. I had some other ideas in mind from other builders (Janos & Doris Obručová’s brilliant work) and worked around their elocutions.
I have totally forsaken any obsessive notion of historical accuracy with this build given that empirical data are very sketchy. I will emulate from other builder’s work details in attempts to improve my skills..along with some reference books, and notations in other builder's logs
Oh Paul those Vasa treenails of yours still cause me some compulsion when I look at my pearwood hull and think of your amazing work --- hahaha…..
Images are generic just filling-in some spaces regarding the last posts…The full view is from Seppings
Cheers,
View attachment 274798View attachment 274799View attachment 274800View attachment 274801View attachment 274802View attachment 274803
I was just taking a cue from the image you posted:Paul: I was tempted to leave those old Corel Vasa lions bright plated - will revisit your suggestion. Interesting that you would make that notation – Are you suggesting that I leave the heads in gold and just add some paint to the outer edges of the mains? thanks..
Slight variations in color may appear on the paintings I mentioned above to be all gold. It seems logical that this is the sort of coloration you would see on a coat of arms.I was just taking a cue from the image you posted:
If you look closely the lion is darker than the filigree and leaves (which I interpret to be gilded). That must mean the lion has been painted like the horse??? It's a minor point so whatever you do will look great - but you do have a reputation for being a stickler for details. Don't forget what I told you when I sorted out your nom de plume... "whenever I play ship model builder with my friends I always ask to be you..."
