After having posted my acrylic dust cover and two acrylic supporting "saddles" for the hull and dory boat with the sail I realized that I should have done that in this log.  So here I go again in a duplicate post.
As I recall I posted the support for the schooner hull which allows me to reposition the hull:
My thought was to have an adaptable support with as much transparency as feasible.  There is an additional acrylic channel for the dory with sail:
This dory has a trawl line aft to a marker float.  Short lines for hooks and catch will be added to the trawl line before the dory presentation is set.  By moving the dory around I can show the scale of both vessels:
When done and the dust removed both will be placed under the large five-sided box dust cover.  I don't have proper lighting for photos or space other than above the den computer but the transparency of the cover is what I wanted.  When the sailed dory is finished I will rotate the box up and slide the dory beside the schooner.
