Brilliant Heinrich! She is going to be a beautiful little ship!
I cannot wait for the day that I can hit this walnut with Tung Oil though - I think it is really going to be all color! Now I still need to put down one plank on either side so that the transom is fully planked and then it's on to the garboard strakes.
Thank you Ron - it is much appreciated. That wood color is the reason why I love working with the Kolderstok walnut. I know that their oak is also beautiful, but I just prefer a darker hull color.That wood is beautiful now and will be gorgeous when hit with the oil.
That wood is gorgeous! And the planking is perfect so far! This going to be a beautiful ship.Hello Everyone. Work in the Nantong Shipyard continues unabated, but planking below the wales now, means that the going is S-L-O-W.
Even with the planks already laid down, it still sometimes requires a "re-adjustment". Here the push pins on the four bulkheads indicate that such an "adjustment" is in still in progress - hence no sanding at all on the portion below the wales.
The Port Side however, is up to QC and has been provisionally sanded. It is simply amazing to see what light does to the color of the wood. This picture was taken with the natural light coming from the bow's side.
But turning it so that the light squarely hits the side of the ship, creates this effect.
And when it is turned even more, this is what it looks like.
Thank you so much my friend. Obviously everything that I said to @dockattner Paul, about artistic flair and ability applies in equal measures to you as well and as such your words are highly appreciated! So far, I am very happy ... but you know how it goes ... with each plank that is laid down now, the pressure of maintaining that elusive "perfect" planking mounts. It's measure, cut, shape, fit, repeat and repeat - throw the plank away - and start all over ... sigh!That wood is gorgeous! And the planking is perfect so far! This going to be a beautiful ship.![]()
Indeed, that makes two of us.
Ja
Too old to start another hobby?????? It is too late to stop now!!! RichHello Everyone. Work in the Nantong Shipyard continues unabated, but planking below the wales now, means that the going is S-L-O-W.
I cannot wait for the day that I can hit this walnut with Tung Oil though - I think it is really going to be all color! Now I still need to put down one plank on either side so that the transom is fully planked and then it's on to the garboard strakes.![]()
Thank you! Despite any strengths I may have artistically, hull planking is a different art in wood working, that you can only learn by building ships. I have yet to perfect it, but I’m learning with every ship I build! My goal is a no putty single plank!Thank you so much my friend. Obviously everything that I said to @dockattner Paul, about artistic flair and ability applies in equal measures to you as well and as such your words are highly appreciated! So far, I am very happy ... but you know how it goes ... with each plank that is laid down now, the pressure of maintaining that elusive "perfect" planking mounts. It's measure, cut, shape, fit, repeat and repeat - throw the plank away - and start all over ... sigh!
Hello Maarten. Thank you very much for the kind words. I am not sure whether it will be clean before Christmas - the goal is to have the planking finished by New Year! Also thank you for the kind wishes re the moving that lies ahead. I wish you and your family a very blessed Christmas and a healthy 2022!Very nice again Heinrich, seems your kitchen will be clean before Christmas.
Wishing you and the family some wonderful days in these exciting days with moving houses etc.
Hi Daniel. I use my plank bender to bend the planks so breakages of planks around curves are not the problem. Because bulkhead #6 was not faired enough it creates large gaps as the plank travels from the preceding bulkheads to the following ones. So there is no mystery here - my fairing of Bulkhead #6 was up to ****. I don't even have excuses.Heinrich it is hard for me to tell from your pictures what the problem is, the wood is so beautifully grained it seems to mask your situation. I do understand walnut though and I imagine the grain fractured around the hard bend. You probably know this but incase not, someone mentioned a while back about using a womans curling iron as a heat source in plank bending. I can tell you it works absolutely fantastic for me when bending in the x;y plane. Quite often I don't even need to soak it. You have an exquisite hull planking going on and like you say I too am looking forward to the oil treatment.
Luckily I am a small eater Ron, so too much pizza won't be a problem,Heinrich,
Take a step back a deep breath and enjoy your “Western” lunch. Things will look better. Unless of course you stuff yourself with too much pizza.
From what I see there is a definite bulge at #6
Ron
Well, I hope I can walk them back Paul. For tonight though, that is that - the bulkheads are simply too wet to do anything.Rookie mistake maybe - but it takes a master to walk them back. Huzzah!
Luckily I am a small eater Ron, so too much pizza won't be a problem,. I am not too perturbed by all of this, but I am frustrated and angry at myself for wasting three days and for making a real rookie mistake. Just unacceptable.
