Panart battle deck section x2 kit mash up [COMPLETED BUILD]
Welsh, LA
I am currently in the process of building a kit mash up of 2 of these kits. Your eyes aren't playing tricks on you. 20211124_034422.jpg
Here I am joining the 2 frames of the kit and adding some bracing with the 2x5 strips.
Here are all the frames joined together. Total footprint of this one will be 21" x 10"20211125_192616.jpg
Getting frame bracing in and placing a mast section.
Scratch built a capstan for this model too.
Getting things mocked up for placement.
Showing how it will be once it's in place.
Figured I'd put some bolts in it.
Laying down some decking
More decking going down.
Fitment of the grating is in
More decking and painted the mast section and have some rope lashing on it. Will be adding spears to it later on.
Planking on the bottom deck is complete.
Inserting toothpicks
Bottom deck nails are in
Just a sea of toothpicks
Everything is clipped off and sanded down and has a coat of light walnut stain
Close up of how the nails turned out.
More test fitting.
Starting to lay the sides on.
Side is complete now for the nails
Sanded and stained and even got the rubbing painted and on.
Got the inside of the bulwarks done.
Putting the hanging knees in place.
Painted the inside of the bulwarks red and added some aging with staine
Now working on the other side.
Checking to see how the cannon will look in place. Not done with rigging quite yet
Checking this out
Jig I made for the cannons
Same jig
Starting on the top deck now
Floor view
Top deck
More of the top deck
Top deck complete now for nails
More nails
Fully rigged cannon
Frame is painted and aged
Columns are in place
Spears are on the mast
So this explains why I hadn't seen the full width kit before.
I do have the basic kit use, never thought of doubleing it up to full cross section.
OK your other post on this subject explains how you got where you are on this.
Do you have plans for the cannon rigging station. I have seen others use such a thing on ships with dozens of guns per deck.
I have been told to help keep the black in color, to make sure you clean the brass pieces well first, to remove any coating or finger oils that may have attached themselves during manufacture to inspection.
Many have said a good wash and rinse in 70% alcohol works well, then rinse in distilled water and dry with gloves on.
I will definitely have to try this.
