Thx gents.
Back to the deck. I am starting on the spaces in front of the ship. 3 rooms from PS to SB the boatswain store, stewards room and again a store.
Again the bulk heads are made from laser cut cherry.
I first glue in the frame posts before cutting out the doors.
After sanding I lacquer the parts with clou primer followed by sanding with steelwool.
The doors made from vertical strips and filed to properly fit.
On the inside of the doors battens are fitted.
Below the bulkhead you see the rings for the doors.
After burnishing dry fitting the hinges and fitting the rings.
On the doors I made latches to close them, these I made from hammered 0,35 mm brass wire.
The doors are finished and dry fitted on the bulkhead.
