Sounds like good logic to me!I think I should explain a little why I changed my focus from building the frames to the assembly of the keel.
As a kind of overture I started work on the Bluenose with frame #8. While in work, I realized that I wanted to be able to check the relevant interfaces of the frames, first with the main jig, where the tops of the frames fit in notches, and second with the keel assembly, where the notched lower parts of the frames slide over the keel assembly. I want to be able to check the fit of each and every frame and I also want to make sure to lower edge of the (beveled) frames aligns properly with the rebate of the keel assembly.
So that's the reason the keel assembly is now slowly taking shape, prior to the assembly of the frames.
Adjustments like death and taxes cannot be avoided IMHO. Afterall, "life is what happens when you are making other plans".Sounds like good logic to me!
At the end of the day, regardless of which order you build them, the adjustments will have to be made for the jig and the keel.![]()
Unfortunately no Starbucks nearby...Oops - that is unfortunate. However, your fix should work perfectly. I agree with you on taking a break if things don't go according to plan. It clears the mind and when you return, you tackle the problem afresh.
Hello Peter,Hi Johan,
I've read the progress of the past few days. Changing a schedule or good grounds is never wrong. And do something different, in-between getting rid of laser cool on 54 frames, is never wrong.
And the frames are indeed fragile. Especially those with the slightly longer truss ends.
I assume the last photo of post #48 is for asking a reply? (Something is upside down). What calls for a response.......
In any case: well done so far!
Have to be candid. . . your keel line pointing to the Gulfstream G650 took my mind off of the schooner and into the sky. I don't recall seeing the YQ frames being set up and the keel down before. Possibly too many lingering views of the frames and keel in the "cathedral" format. Two wheeled horse rides are a good way to refocus your mind and hands as you progress. Slow and steady as you go. Rich (PT-2)That was a nice, although chilly, bike ride, enough to clear my mind and continue work on the frames. A local restaurant offered takeaway cappuccino, so no further need for Starbucks...
Now frames #2 through #7 are bonded.
Frames #4 through #6 have the two long frame halves spliced in the centerline. Based on my repair of frame #3, I decided to use a pin to reinforce the joint. I hope to benefit from this feature later in the build, especially when aligning the frames with the keel and the assembly jig. I am counting on obtaining sufficient rigidity when all frames have been bonded to the keel, than the pins have become obsolete.
Progress, however small, has been made!
Yep, the beautiful G650. I was the design lead for the tail’s main composites during its development, but that was another era. Still having fond memories of the visits, paid to Gulfstream at the timeHave to be candid. . . your keel line pointing to the Gulfstream G650 took my mind off of the schooner and into the sky. I don't recall seeing the YQ frames being set up and the keel down before. Possibly too many lingering views of the frames and keel in the "cathedral" format. Two wheeled horse rides are a good way to refocus your mind and hands as you progress. Slow and steady as you go. Rich (PT-2)
Yes, it is about the journey/voyage and not the ending pier. RichThe initial work seems to go on forever…lol…gluing and beveling frames, and of course building the keel. Then adjusting notches in the keel and jig. Eventually you will have them all finished and glued together. After which you will be doing the internal framing! So don’t rush…all in due time!![]()
Rich, You're absolutely right. Thanks for reminding me.Yes, it is about the journey/voyage and not the ending pier. Rich
